Another dead Battery
Old Oct 3, 2007 | 01:48 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Originally Posted by c5chines
Try disconnecting the battery tender.That was my problem.
Did the Battery Tender go bad?
Originally Posted by mrm1149
You must not have been using a good phase(stage) charger..........
I'm using the DELRAN Battery Tender. This is supposed to be one of the best on the market. Should I get something else?
Originally Posted by Dave68
The AC Delco Professional batteries have been thoroughly redesigned and now have a much stronger case, especially at the terminals. Another plus is their 50-month free replacement warranty - best in the industry. I say you made an excellent choice.
I hope your correct.
Old Oct 3, 2007 | 02:21 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
The charger Question was addressed to C5chines" comment, If the Deltran is a phase charger you should be in good shape chargerwise
Old Oct 4, 2007 | 08:23 PM
68sixspeed's Avatar
68sixspeed
St. Jude 15 Year Donor
St. Jude Donor '10 thru '26
I went through 2 optimas under warrantee before finally throwing the darn thing out and putting a normal interstate in - no problems since. I had originally tried the optima in my camaro and I couldn't even get through setting the valves without it needing a boost/charge. I'm a bit nervious with a normal battery over the computer from a leak standpoint, but I added one of those acid absorbing mats to be safe.
Old Oct 4, 2007 | 08:38 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Originally Posted by Challenger
4 years out of this Optima Red Top. I might drive 500 miles per year Car usually gets the miles 1/4 mile at a time. When it's in the garage it's on a battery tender.
Can anyone tell me if this would be normal to kill a battery even with a tender on it?
I see your problem. You don't drive it nearly enough.
Old Oct 4, 2007 | 08:42 PM
88sk's Avatar
88sk
Originally Posted by Bugaboo
Gotta agree here even though I have a red top ...Next will be exide when needed.
same here , I think they are way overrated,they look cool ,then there are the guys that talk about leaks ,as far as I know that was mostly with the OE batteries, better off goin to autozone or someplace else to get a battery for half the cost
Old Oct 4, 2007 | 09:19 PM
16Again's Avatar
16Again
I installed the new battery today and she fired right up.
Swapped out the slicks and skinnies for some street wheels and tires. This weekend I'll take the wife for a cruise somewhere and let my baby stretch her legs for a few miles.
Thanks to all of you for your input.
This is the new unit I put in.
This is before I swapped the wheels.
Old Oct 4, 2007 | 10:47 PM
mvvette97's Avatar
mvvette97
Originally Posted by briann510
Thats just not right. You have a amp draw somewhere and need to get out the ohm meter and track it down. Some stereos/amps draw enough with car off to drain battery over a few weeks.
well mine is not my amp because I always disconnect it when it sets. You know of a good writeup that tells how to check to draws?
Old Oct 5, 2007 | 08:11 AM
c5chines's Avatar
c5chines
Yes my battery tender went bad.It checked out fine when plugged in and actually charged the battery, but I believe a diode failed inside the tender allowing the battery to discharge itself over the course of a few days through the tender wires if the tender was not plugged in.I don't recall what brand of tender it was.
Old Oct 5, 2007 | 09:48 AM
FireLieutenantPhilly's Avatar
Default Auto Zone Duralast Gold.
Maintenance Free 3 years old, still needs to be put on trickle charge if not driven for a week to 10 days. But 95% fires right up,, now the radio stations are another issue................and seat memory forget it.
Old Nov 12, 2007 | 06:11 PM
EGbeater's Avatar
EGbeater
Have you had to take up Autozone on their 3-year free replacement warrranty on the Duralast Gold battery?
Old Nov 13, 2007 | 08:01 AM
99 vett babycar's Avatar
99 vett babycar
Originally Posted by RGAZ
I have had the same issues with Optimas. I keep them on trickle chargers now. Rarely get two years out of them. Had two die a few months ago. Put the red top from the vette in the DOA Jeep. Put a yellow top in the C5. Will see if it lasts longer. I put an Exide Orbital in the DOA Pantera. I am sick of DOA Optimas.
the yellow top sucks just as bad as the red top
