Replacing Passenger Air Bag Door
Old Oct 1, 2007 | 12:09 AM
Choreo's Avatar
Choreo
Default Replacing Passenger Air Bag Door
How much of a pain would this be? I was thinking of having it covered in an embroidered leather.
Old Oct 1, 2007 | 12:43 AM
Jistari's Avatar
Jistari
I was looking at this also, for another reason. Was thinking of mounting a display there (ya, I know, shades of airbag deployment, waking up in hospital and finding that my passenger now has the display permanently mounted in their head). But wondered if the air bag blew from the bottom (forcing the cover up, hinged on the top), from the top (forcing the cover down, hinged at the bottom) or just split in the middle ?
Anyone know ?
(looked for pictures of deployed passenger airbags and checked the parts drawings, cant tell).
Old Oct 1, 2007 | 03:50 PM
SilvaDragon's Avatar
SilvaDragon
DON'T mess with the airbag facing.
The covering on airbags is calibrated to tear with the specific
force of the airbag. Any item on the facing will be propelled at
the passenger with tremendous velocity.
The airbag deploys by tearing a hole in the center of the cover.
The cover is designed so that it will tear cleanly and not send
chunks of cover at the passenger.
Just...don't.
Old Oct 1, 2007 | 09:29 PM
Jistari's Avatar
Jistari
<tap tap tap tap (walking over to ToDoList)....select black marker......screeeeek screeeeek (crossing off Display Mounting Idea).
Old Oct 2, 2007 | 07:52 AM
Midwest Vette's Avatar
Midwest Vette
Just...don't.
Old Oct 2, 2007 | 06:49 PM
coanan's Avatar
coanan
The C5 Pass airbag does not split in the middle. It is hinged at the top and the bottom and sides separate blowing the flap up.
Old Oct 2, 2007 | 08:36 PM
SIB's Avatar
SIB
passenger side cover just flips down upon airbag deployment, so it could be wrapped in leather
to get to it you must pull the dash pad, its a simple job
Old Oct 2, 2007 | 08:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
pull dash pad, pass bag is bolted in through the bottom, 4 nuts; the cover actually slides off the bag assembly, I swapped one once, someone decided to superglue the 'corvette' letters into the cover
Old Oct 2, 2007 | 11:25 PM
Choreo's Avatar
Choreo
This is the response I was expecting. In the photos I have seen where the airbag deployed in a collision it looked like the cover just hinged at the bottom and swung out of the way when the bag deployed and stayed attached or very close to the dash panel.
To Replacing Passenger Air Bag Door
