Need help with diagnostic code P0442
Old Oct 1, 2007 | 11:37 AM
red02c5's Avatar
red02c5
Cruising
Default Need help with diagnostic code P0442
My check engine light came on over the weekend. I ran the codes and came up with one current code.
10-PCM P0442 C
The closest code I could find is P0441 EVAP System No Flow During Purge
What does this mean in english?
Thanks for your help.
Old Oct 1, 2007 | 12:41 PM
87SAM's Avatar
87SAM
Did you put gas in over the weekend. Maybe the cap is not tight or bad. It happens occasionally. Try this link:
http://www.gearchatter.com/viewtopic10457.php
Old Oct 1, 2007 | 02:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Check your gas cap as the first thing they do in the diagnostic for this code is check the gas cap. Here is the theory of Op.
DTC P0442
System Description
This DTC tests the evaporative emission (EVAP) system for a small leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the vacuum decay rate. At an appropriate time, the control module turns the EVAP canister purge valve ON and the EVAP vent valve ON. This allows the engine to draw a vacuum on the EVAP system. At a calibrated time, or vacuum level, the control module turns the EVAP canister purge valve OFF, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum decay. If the control module detects a leak larger than a calibrated amount, this DTC sets.
Bill
To Need help with diagnostic code P0442
