Blowoff valve sound.
Oct 2, 2007 | 10:00 PM
I have a 03 Z06 and when I rev it up and let off the gas it sounds like it has a blow off valve. Does any body know why.
Oct 3, 2007 | 11:52 AM
is it only when you let off the gas? Does it drive normally?
Oct 3, 2007 | 11:58 AM
Quote:
Originally Posted by
GOTPSI
That is weird.Excuse me for this dumb question but first and foremost,do you know what a BOV sounds like?
Oct 3, 2007 | 12:09 PM
Maybe the car is turbo/super charged
Oct 3, 2007 | 01:10 PM
Cruise-In VIII Veteran
Why choose a name like "GOTPSI" if you don't have FI? Hmmmm....you playin' with us?
Oct 3, 2007 | 09:44 PM
Yes I know what a BOV sounds like. The reason I have the name GOTPSI is cause I have an 04 Cobra also and that is my tag and I also use it on the other forums. Its is only when you rev it up and let of the gas, like a blow off valve and the car drives fine. I did not know if these cars do this when you have a diff air intake.
Oct 3, 2007 | 10:30 PM
These LS1/6 Have been know to make a whistling sound in the intake. My 03 does it at certain RPM,Engine loads,
Here is what GM says about whistling intake:
http://www.corvetteactioncenter.com/...ke+Manifold%29
Oct 4, 2007 | 10:26 AM
Oct 4, 2007 | 11:15 AM
does it olny happen the first few minutes after start up? could be your air pump. I notced it with my camaro but not really with the vette.
Oct 4, 2007 | 11:18 AM
maybe your car has whistle tips?
Oct 4, 2007 | 10:55 PM
jirasvet
Thanks for the info.
