I have a 2000 6spd that is having some problems. I have noticed for a while EVERY ONCE IN A WHILE, when i get on it the clutch will stick (sticks to the floor kinda). Even though it dont happen a lot it does happen if I go to get on it hard some times. Then the problems got much worse, on my way home it was acting really messed up. It felt like the trans was going out. It would go if I babied the gas but if I didnt press it just right it would fell like it was in (N) and just rev up. By the time I got home it would feel like it was in (N) the whole time and NOT MOVE just put it and gear and NOTHING AT ALL. just revs up. I was told its prob a drive line support or a prop shaft and I will prob need new clutch sleve and master cly. for the clutch (the reason why the clutch sticks at times) I figure while they are in there might as well get a new clutch put in it as well. Does this sound right?
It sounds like your pressure plate or disc is worn out.
Best way to check is to put car up in the air and remove the lower bell housing access plate to inspect the clutch and the associated parts.
Don't thing it's a brake fluid problem based on the fact that you can not move.
I would also try putting the car in 1st gear in an open area. Press the clutch down and start the car. If the car lurches forward then you may have a bad slave, or fluid problem if not it's probably the clutch itself.
Yep, had it done last month, no problems every since, but have listened to AGJ, and Ranger on keeping the fluid clean and clear with Dot 4 synthetic. Follow RANGER's protocol on clutch fluid syphoning.
ok i was told today it was the torque tube and shaft.
When my TT bushings were going bad I picked up a very strong vibration under moderate acceleration but it did not affect the clutch action at all. Lots of people have the "Sticky Clutch Syndrome". Try changing the clutch fluid. If that doesn't work - it's new clutch and hydraulics time.
Wow. well the clutch problem i have had since i owned it i am sure is not the problem that is wrong with it now. I mean now it wont move at all, and the guy fixing it is one of the best there is on working on these things. Danny popp many of you may know him. he said its the torque tube that is snapped on the inside of the tube
It's pretty simple to find out. Remove the bell housing inspection plate, put the car gear and turn the rear wheels. If you can turn the wheels and the clutch/flywheel doen't move you know it's aft of the clutch.
