Tapping into remote unlock feature.
Old Oct 3, 2007 | 07:30 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Tapping into remote unlock feature.
I have a black car and would like to put a single blue LED behind the outside Door handle. I'd like it to come on like the foglights when i unlock the car remotly. Anyone know where to tap in to?
(I will also be posting this in the Electronics section, but since it's a C5 thing I'll have it here as well)
Thanks in advance.
Old Oct 3, 2007 | 07:36 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Led's?
If you did that, wouldn't it be on when ever the fog lights were on? Like when you are driving down the road? I would first trace down the foglight fuse location in the car from the owner's manual then check with a voltmeter while using the fob and see what happens. You might also see about hooking it up to the same bulb in the dash as the "SECURITY" light? Good Luck and be sure and let us know what you did to make it work, just in case for other forum members.
Old Oct 3, 2007 | 11:06 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I"ll definatly look that up. I'm thinking the interior security lights might be what i need. If that's the case, It should be easy.
To Tapping into remote unlock feature.
