N20 technical questions
Old Oct 3, 2007 | 09:15 PM
skydive120's Avatar
skydive120
Default N20 technical questions
Im looking at hooking up a ZEX wet shot on a 2000 C5.
Have everything coming including a window switch.
What is still needed are the wires one uses to the throttle position sensor (TPS) and tach signal wire for the window controller (location/color).
Plus, anyone know what the sensor circled in red is for (see attached)
Can I use it for my jets?
Thanks to all!
Chris
Old Oct 3, 2007 | 09:48 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
The sensor is your IAT sensor, and you need it there.
Here are pinouts from the manual.
http://forums.corvetteforum.com/show....php?t=1458041
Old Oct 4, 2007 | 12:11 AM
skydive120's Avatar
skydive120
Thanks Bluewire-- great link!!
So next question, where is a good place for the nozzels??
Opisite the sensor?
Chris
Old Oct 5, 2007 | 11:19 PM
cpow22's Avatar
cpow22
Opisite the sensor?
Chris
On the opposite side of the air bridge there should be a flat quarter size tooling mark that makes an excellent flat surface to mount the nozzel. Drill a hole in the center and then use the tap include in the kit to thread the hole for the nozzel. I mounted the nitrous management unit on the drivers just off the upper corner of the stock air box assy and ran the lines underneath the air bridge. Be careful when mounting the nitrous management unit on the radiator shroud if you go this route as the top of the AC condensor and radiator are directly behind. You also want to make sure that your position will alllow the hood to close properly.
Also, when hooking up the lines to the management unit be very careful not to rotate the fitings on the management unit as this could compromise the internal seals. Use one wrench to hold the fittings on the box stationary as you tighten the fitting on the line. Lessons learned (and paid for) from a do it your selfer! Good luck on the install
Old Oct 6, 2007 | 01:50 AM
skydive120's Avatar
skydive120
Thanks for the info Cpow22!
It will be a few weeks before I can get this installed, but all this help makes is much easier!
chris
To N20 technical questions
