Fuel sensor cleaning???
Old Oct 5, 2007 | 08:00 AM
c5chines's Avatar
c5chines
Default Fuel sensor cleaning???
Anybody recall where the procedure can be found for removing and manually cleaning the swipe boards for the fuel level sensors? (97)I seem to recall someone doing a write up on the procedure and results.I've had it with the gauge going to zero on a full tank and don't like paying $3.15 a gallon for premium,so adding a $8 bottle of techron every tank that doesn't work isn't an option. I figure if I can change the in tank fuel pump in a Blazer in an afternoon by myself, I could probably handle the sensor cleaning.Yes I have the factory manuals if needed, but real life experience might be helpful before I start. Thanks-Chuck.
Old Oct 5, 2007 | 01:25 PM
jirasvet's Avatar
jirasvet
Hope this helps
http://www.cajundude.com/racetronix.htm
Old Oct 6, 2007 | 11:41 AM
c5chines's Avatar
c5chines
Thanks!!!
To Fuel sensor cleaning???
