a vibration or grinding when turning slow
Old Oct 5, 2007 | 08:03 PM
neokorros's Avatar
neokorros
Default a vibration or grinding when turning slow
i can feel a vibration or grinding of some sort when turning slow (especially when turning right) in the gas pedal.
anyone have any ideas what it could be ?
~ nick
Old Oct 5, 2007 | 08:13 PM
lar66BB's Avatar
lar66BB
Default vibration
Maybe the posi unit. Might need a additive you can get it at the
dealer. Slang for it is whale oil. It lubes the clutches in posi unit
of the rear end. Hope that is what it is.
Old Oct 6, 2007 | 01:18 PM
neokorros's Avatar
neokorros
ty
Old Oct 6, 2007 | 08:35 PM
neokorros's Avatar
neokorros
anyone else have any suggestions as to what it might be ?
what components could even cause a grind feeling in the gas pedal when turning right ?
Old Oct 6, 2007 | 10:22 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Check the wheel bearings and hub assemblies. Jack the car up and check for any free play in the wheel assemblies by gripping the top and bottom of each tire and then trying to push or pull on the wheel. Do the same from test gripping the left and right side of each tire.. Rotate each tire and see if you hear any grinding noise. If you notice the noise more when turning right, suspect one of the left side bearing hub assemblies might be going bad since the left side wheels are loaded in a right turn
Other areas to check would be rear differential lubrication, suspension components loose, crack in wheel, brake calipers and mounting brackets loose. Also check th rear parking break assembly as sometimes parts fail or come loose inside the drum and create a ginding noise.
Do a search in C5 Tech under Wheel Bearing Noise. You will find all kinds of posts there. Good luck with it.
Old Oct 6, 2007 | 11:23 PM
Cart99's Avatar
Cart99
If the noise is most noticable during slow speed sharp turns or u-turns, it's likely the differential positraction clutches. As suggested, the first thing to try is a diff fluid change with the correct positraction additive. Worst case is a complete diff rebuild (don't ask how I know). Hopefully yours is something cheaper.
Old Oct 6, 2007 | 11:58 PM
500hp's Avatar
500hp
I see that you have headers...
are the driver's side tubes contacting the steering shaft?
Old Oct 7, 2007 | 02:05 AM
Bluefire's Avatar
Bluefire
My 2:73's started making noise about a year ago. Diff fluid change helped for a short while (6 months) then it came back. When you change your diff fluid check to see if there are any shiny metal chunks in it. Mine did.
On the bright side, it forced my upgrade to DTE 3:42's sooner.
Old Oct 10, 2007 | 10:28 PM
neokorros's Avatar
neokorros
i havent had a chance to change any fluids yet, but i noticed today it is putting counter pressure on the steering when i turn right at slow speeds.
example: i am going 10mph in parking lot and make 90 degree right turn with foot on gas in first gear.
i can feel a grinding/vibration in the gas pedal itself and its harder to turn the wheel to the right as if some force is slowing it down.
Old Oct 12, 2007 | 12:23 PM
Richy1's Avatar
Richy1
From: With great power, comes great responsibility... ..."Uncle Ben"
I’m getting the same symptoms but I feel the vibrations when doing anything over 10 mph. Even when I’m on the highway going 60 mph on a subtle right turn I can feel the gas peddle vibrating. I changed my transmission and diff fluid a month ago, I’m not getting any noise or vibrations under sharp right or left turns.
Ex: When I do figure eights, I hear and feel nothing. When I go on an entrance ramp to a highway (right turn) or going around a turn at high speed I feel the vibration in the gas peddles.
This is driving me crazy...
Old Oct 12, 2007 | 01:59 PM
CO YGOSLOW's Avatar
CO YGOSLOW
Just had the same problem fixed...the noise is the rear diff clutch chattering. Need to put an additive in with the diff fluid.
Old Oct 12, 2007 | 09:28 PM
neokorros's Avatar
neokorros
what additive ?
Old Oct 12, 2007 | 10:04 PM
CoastalRAP's Avatar
CoastalRAP
Originally Posted by neokorros
what additive ?
Old Oct 13, 2007 | 12:36 AM
allmee's Avatar
allmee
what additive ?
I did my rear end fluid a couple of months ago, but I used Amsoil severe gear oil, which needs no additive at all. Nice and easy! That is if you are gonna do the rear fluid!
To a vibration or grinding when turning slow
