HID problem after install. yes I searched.
Old Oct 7, 2007 | 11:10 AM
tommybilt's Avatar
tommybilt
Default HID problem after install. yes I searched.
These silly things dont light up. I tested power right into the plug that goes to the ballast. But no power comes out of the ballast. Am I missing something or are these things designed like those Hess toy trucks where you have to pull the tab of paper from the batteries so they work? Or perhaps through the ballast against the wall?
Thanks.
Old Oct 7, 2007 | 11:12 AM
1FUNC5's Avatar
1FUNC5
what brand do you have?
Old Oct 7, 2007 | 11:14 AM
tommybilt's Avatar
tommybilt
shEBAY
Old Oct 7, 2007 | 11:16 AM
1FUNC5's Avatar
1FUNC5
have you tried flipping the connector coming from the stock wiring harness? My kits required the connector to be plugged in backwards for lamps to ignite.....
Old Oct 7, 2007 | 11:20 AM
tommybilt's Avatar
tommybilt
negative, I just plugged it in the way that had the keyway or snaps that line up. Lemme try that.
Old Oct 7, 2007 | 11:22 AM
1FUNC5's Avatar
1FUNC5
I'll be here just let me know if that works
Old Oct 7, 2007 | 11:23 AM
tommybilt's Avatar
tommybilt
You sir are correct. They work. Thanks again.
Old Oct 7, 2007 | 11:24 AM
1FUNC5's Avatar
1FUNC5
You are very welcome....I have low/high/fogs in my car and every set wires the same......
Old Oct 22, 2007 | 11:52 PM
5W0P3's Avatar
5W0P3
Wow, this thread was a life saver.
Old Oct 23, 2007 | 06:27 AM
rws.1's Avatar
rws.1
I had the same problem with mine and I too was saved by the Forum.....
Old Oct 23, 2007 | 07:35 AM
minitech's Avatar
minitech
I had the same problem. Wonder why they make them so the connector has to be put backward? I was on the phone to phone support and almost pulled them out before trying to change the connector to the backward looking way but then they worked. At least it CAN be placed backward.
Old Oct 23, 2007 | 07:48 AM
Bugaboo's Avatar
Bugaboo
Originally Posted by minitech
Wonder why they make them so the connector has to be put backward? .
Yeah, why is that?
Old Oct 23, 2007 | 10:02 AM
NJAnthony's Avatar
NJAnthony
Add me to the list. I installed my HIDs about two months ago, same problem. However, when I tried to pull the spade out of the connector, the spade stayed in and the wire can out...
I found a replacement connector with wires on fleabay, so I just spliced/soldered/wrapped the cables to the new connector...
Old Oct 23, 2007 | 12:27 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
That's the strangest working solution I've heard for the HID kits. But I suppose if it works it's a simple fix.
Old Oct 23, 2007 | 12:33 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I remember reading that the foreign cars are wired the opposite of ours and they didn't reverse the wires for the one's sold in the US.
I had same problem with a set I bought off of ebay for my Jeep.
I got one of those pin picks and poped out the wires and reversed them.
Also had to reverse the wires on my Bro's FRC when changed the ballast. He has the not-mee HID set-up in his FRC.
To HID problem after install. yes I searched.
