Looking for EBCM relay (C1214)
Old Oct 7, 2007 | 07:46 PM
mcarota's Avatar
mcarota
Default Looking for EBCM relay (C1214)
I have code C1214 for the electronic brake control module, have removed the part and taken the module apart. There is a relay inside that is the problem....does anyone know where to buy this relay?? The fix will be simple once I can find the part. Thanks in advance!!!
Old Oct 7, 2007 | 08:29 PM
RedSoxFan's Avatar
RedSoxFan
If there's a part number on it maybe you can find it at digikey.com? I bought the door lock relay there (thanks to this forum ).
Old Oct 8, 2007 | 06:38 AM
trussme's Avatar
trussme
Call Brandon...he has these relays:
For EBCM repair/replace
Call Brandon
877-648-7530 at ABS FIXER
Old Oct 8, 2007 | 09:33 PM
Mac11's Avatar
Mac11
How about some pics of the EBCM blown apart and the relay thats bad identified ? I'd really like to fix my own ECBM and intend to take down in the spring.
Old Oct 8, 2007 | 10:24 PM
mcarota's Avatar
mcarota
working on the pics, hopefully have them posted tomorrow...left the camera at work today.
Old Oct 8, 2007 | 10:28 PM
jirasvet's Avatar
jirasvet
Old Oct 8, 2007 | 11:34 PM
striper's Avatar
striper
I hope before you took everything apart you checked all other possible causes for the 1214 code. I had the code appear a couple of weeks ago. Checked for reasons to first cause this code to happen. I tightened the ground connections on the left frame rail and the codes disappeared. I driven my car several times now since the code occurence and the code is now in history only and hasn't come back.
Old Oct 9, 2007 | 07:04 PM
mcarota's Avatar
mcarota
Unfortuntely for me, it was not that simple. Checked all grounds, cleaned them even though they were not bad, then double checked them again...check all of the voltages and too bad for me everything was ok.
To Looking for EBCM relay (C1214)
