F45 lowering question.
Old Oct 7, 2007 | 10:35 PM
STLBLUES's Avatar
STLBLUES
St. Jude Donor '09
Default F45 lowering question.
Will F45 shocks throw codes after lowering on stock bolts? Anyone have a link on F45 shock removal? I assume you have to have edits or sims installed if you remove the shocks. Sorry another lowering thread started I never find the perfect answer using the search link.
Old Oct 7, 2007 | 10:55 PM
BanditDude's Avatar
BanditDude
You will not throw any codes by simply lowering the car. I had a link to the Stopforce site that showed how to remove the shock option with a Tech2 tool...but I can't open their site. Maybe someone else will have an alternate link.
Old Oct 9, 2007 | 12:06 AM
striper's Avatar
striper
It is not recommended to lower a car with the F45 option, the shocks can't take bottoming out. Replace the shocks first and remove the feature from the computer, then you can lower it.
Old Oct 9, 2007 | 04:51 PM
STLBLUES's Avatar
STLBLUES
St. Jude Donor '09
Who has a how to link? Can a dealer remove the code or do you have to use sims when going with a different shock?
Old Oct 9, 2007 | 05:00 PM
FKING1's Avatar
FKING1
My F45 has been lowered nearly 2" for 5 years. Shocks will bottom out on big bumps, but, no other problems.
Old Oct 13, 2007 | 08:03 PM
f355bird's Avatar
f355bird
I also have the F45 suspension and im lowered with no problems
Old Oct 13, 2007 | 09:33 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I had no problem on my F45 equipped car when I lowered it as far as it would go on the stock bolts. Drove it like that for 11K miles before the system got deleted and the shocks were fine.
Old Oct 13, 2007 | 11:39 PM
bdiddo's Avatar
bdiddo
same here
To F45 lowering question.
