Driver Information Center (DIC) button lights out
Old Oct 7, 2007 | 10:57 PM
wreakhavoc's Avatar
wreakhavoc
Default Driver Information Center (DIC) button lights out
My top two lights have gone out ("fuel" and "gauges")
Are their individual bulbs behind these or what?
How to replace?
Old Oct 7, 2007 | 11:14 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
How to replace?
Mine where out for a while, then one day came back on and have been fine since. For the record unless there is a way to get at the gauges without removing the instrument cluster It's a 6 hour job to get at them and get the dash back together, if you have some billet bezel rings now would be a good time to do em.
You have to take the whole dash center console apart to get to the cluster then who know about changing the light.
Old Oct 8, 2007 | 12:24 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Bulbs are easy...getting to them is another matter. The cluster has to come out as the DIC controller is screwed into the cluster from behind.
Old Oct 30, 2007 | 07:46 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default 6 Hours!!!!!!!
woah...time out....6 hours....thats a bit much....I wouldn't say six...3 maybe if you have never done this job....here is a link to get at the bulbs...once it is out...pretty straight forward...replace old bulbs with new bulbs....new color change is optional.
http://www.spdkilz.com/techtipleddic.html
Old Oct 31, 2007 | 12:22 AM
dgrant3830's Avatar
dgrant3830
No, it doesn't take 6 hours. I haven't done it, but the cluster can be removed by lowering the column a little and of course the associated trim pieces there in front. I removed the whole dash pad to replace my HUD a while back and that job start to finish was 2.5 hours.
Old Oct 31, 2007 | 06:45 AM
97vetteman's Avatar
97vetteman
I had my cluster in and out many times it takes me about hour total!
It sure is a PITA as I bulb out now the same DIC top bulb and I now have to spend a hour changing the frikin thing!
To Driver Information Center (DIC) button lights out
