Clutch Suggestions
Old Oct 8, 2007 | 03:54 PM
performanceZ06's Avatar
performanceZ06
Cruising
Default Clutch Suggestions
I sure there are some suggestions about which clutch to install in an 03 z06. Let me here them. I am only going to slightly modify - heads and cam, in the spring, and will be updating with long tube headers next week.
Old Oct 8, 2007 | 08:48 PM
speedsk899's Avatar
speedsk899
Some people believe in the LS7 clutch, and some don't. I like the spec clutches. A spec 3+ is a great clutch.
If you decide to go with the LS7, I will sell you mine.
Old Oct 8, 2007 | 08:56 PM
performanceZ06
Cruising
Single disk, twin disk? Is it better to buy the twin disk now even if I don't upgrade to big power?
Old Oct 8, 2007 | 09:02 PM
speedsk899's Avatar
speedsk899
The spec twin disk is a good upgrade but costs over $1400. The spec 3+ is under $600. The spec 3+ will handle 850ftlbs, where the Spec twin disk will handle 1500ftlbs. I will say that the Spec 3+ will be just fine.
Spec 3+
http://www.lmperformance.com/6224/4.html
Spec twin disk
http://www.lmperformance.com/15459/4.html
To Clutch Suggestions
