X-pipe question
Old Oct 11, 2007 | 10:00 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
Default X-pipe question
Been looking at ARH, and Lg's I noticed some systems come with the x-pipe at the collectors and others have them after the cats. WHich is better ?
Old Oct 11, 2007 | 10:11 PM
jeanlucpicard's Avatar
jeanlucpicard
Doesn't really matter. All the X-pipe does is minimize exhaust pulsing and some of the resonance - no horsepower and virtually no benefit. You can get just about the same effect with a 2" piece of pipe welded between the 2 exhaust banks - which is what GM does from the factory.
Old Oct 12, 2007 | 01:16 AM
Bluefire's Avatar
Bluefire
I just bought the AR LT header system. The hi-flow cats are after the X-pipe. The supplied X-pipe has a much larger "crossover hole" than the standard H-pipe. When you consider the shape of the X design compared to the H design, the exhaust can crossover and balance more smoothly (less turbulent, more efficient) than the H-pipe. Does it make HP? No. Just helps balance exhaust pressure
Old Oct 13, 2007 | 12:01 AM
04tripleblkcoupe
Well guys appreciate the replies, Just ordered Lg's system.
Old Oct 13, 2007 | 12:06 AM
Showdown's Avatar
Showdown
What made you go with lg over the other brands?
Old Oct 13, 2007 | 12:31 AM
04tripleblkcoupe
Really looked at the primary tubes and saw the Lg's were more of a straight flow without alot of bends in the tubing.
Old Oct 13, 2007 | 10:22 AM
Higgs's Avatar
Higgs
you will be happy with the LGs, except that I don't like their clamping system... it tends to be prone to leaks.
Old Oct 13, 2007 | 05:11 PM
04tripleblkcoupe
Anyone else with the LG's pros system having any exhaust leak problem
To X-pipe question
