what should the battery voltage be?
Old Oct 11, 2007 | 10:47 PM
mouschi's Avatar
mouschi
Default what should the battery voltage be?
I just installed a new battery, and after I drove for about 15 minutes, I *think* the DIC said 13.4. I was trying to reprogram my tire sensors tonight after the Corvette was sitting in the garage for a good 12 hours, and checked the battery voltage for the heck of it. It was 12.1 - is this normal? What is the normal range it should be in? Should it flucuate like that depending upon if it has been sitting for a while or not?
Old Oct 11, 2007 | 10:52 PM
TEXHAWK0's Avatar
TEXHAWK0
Are you saying that the DIC showed 13.4 with the car not running?
The short answer is Yes.
The DIC should show the battery charging at between 13.8 to 14.4 with the car running, so right when you turn the car off, it may show 13.4 volts, but will drop quickly into the 12 volt range.
The battery should put out a minimum of 12 volts, but can be higher if it has been charging.
Also, I found that the voltage that the DIC is lower than the voltage if you actually measure it across the terminals of the battery.
Old Oct 11, 2007 | 10:54 PM
mouschi's Avatar
mouschi
i don't remember anymore - maybe 13.4 when running. but 12.1 when not running ... that is for sure at least. i just wanted to make sure my battery wasn't going bad already!
Old Oct 11, 2007 | 10:57 PM
TEXHAWK0's Avatar
TEXHAWK0
A new battery may have been sitting on the shelf for 4 or 5 months and may not be fully charged. After you drive it for awhile, and it is fully charged, you will probably see less fluctuation in the voltage.
I would not be concerned unless you see the voltage drop below 12.
Old Oct 11, 2007 | 10:59 PM
mouschi's Avatar
mouschi
ok, so 12.1 voltage with the car sitting for 12 hours is fine? I did notice that the battery had a sticker on it that said 10/07 on the side. I guess that is the sell by date or something.
Old Oct 11, 2007 | 11:03 PM
TEXHAWK0's Avatar
TEXHAWK0
Yes. It depends on the brand of battery where it is, but most batteries have a date code somewhere that tells when the battery was made.
Old Oct 11, 2007 | 11:38 PM
Oldvetter's Avatar
Oldvetter
Measured with a volt meter across the battery terminals a 12-volt battery will measure at about 12.9 volts when it’s fully charged and about 11.4 volts when it is fully discharged.
Old Oct 12, 2007 | 02:07 PM
mouschi's Avatar
mouschi
ok i looked at it while shut off this morning ... last night it was 12.1 and this morning was 12.0. It immediately shot to 13.7 or so when I started it up, but could it be something is draining the battery? Sorry if I sound too concerned about stupid stuff!
Old Oct 12, 2007 | 02:25 PM
BlackZ06's Avatar
BlackZ06
The reason it jumped to 13.7 is the alternator is producing power once the engine is running and is charging the battery. The DIC should show high 13 to about 14 volts with the engine running.
Probably the best thing you can do is to take the car out for a good highway run this weekend. Think of a fun place to go that will take an hour (or more) to get to at highway speeds (over 50 MPH). Go there, have a good time, drive home. That will ensure a good charge of the battery.
Over the next few days check the battery voltage (sounds like you have another car so let the Vette sit for a few days). Report your voltage readings, and we'll see if it looks like you have an excessive drain on the battery.
Old Oct 12, 2007 | 02:31 PM
mouschi's Avatar
mouschi
thanks Steve! I dont' think I'll be able to do that this weekend unfortunately - we just adopted a little girl, and paired with our son, they are both driving my wife nuts! Before we adopted, if you were to ask her what day it was, she wouldn't be able to tell you the difference between a weekday and weekend (other than me being off of work). Now, she loooongs for weekends so I can be of some relief to her from the kiddos (haha). They are quite the handful! But anyway I think going away for an hour ... in the car she didn't want me to have in the first place ... may not be the best time this weekend (for other reasons too )
I will be driving it to get the oil changed and brakes looked at though, so I may take the "long" way to get their
Old Oct 12, 2007 | 03:05 PM
Autobot's Avatar
Autobot
Congrats on the new addition to your family.
Old Oct 12, 2007 | 03:11 PM
mouschi's Avatar
mouschi
thanks! she is a blast, but can really tire us out.
Old Oct 12, 2007 | 04:14 PM
BlackZ06's Avatar
BlackZ06
My congratulations also .... and having raised a daughter (she's now 20) pretty much by myself I can more than sympathize with how tiring small ones can be ... all I can tell you is ... if you think it's bad now .... wait 'til they're in their teens !!!!!
OK .... see f you can make the following deal .... take the car out for 30 minutes at highway speed (big loop or out-and-back run) and then get oil changed. Offer her, in return, 3 or 4 hours that she can take off with a girlfriend or relative to go shopping, get her nails done, whatevr, while you take care of the kids. Sneak a bunch of flowers into the house nad surprise her with them when she gets home. Might make things just a LITTLE easier for you to get the Corvette out that way.
Again, congratulations,
Steve
Old Oct 12, 2007 | 04:36 PM
ValiantSailor's Avatar
ValiantSailor
12.6 is fully charged lead acid battery at rest.
Old Oct 12, 2007 | 04:52 PM
mouschi's Avatar
mouschi
Steve, I had no idea you doubled as a marriage counselor!!! That sounds pretty good to me Flowers are a great idea
At least it'll make her happy until she knows I'm about to modify our Impala SS
To what should the battery voltage be?
