Heads & Cam DD step in
How drivable will this combination be? The tuners / speed shops will tell you what they think you want to hear. I am looking for real world information.
I am sure that the fuel economy will change but I have heard that if driven gently it could actually go up.
Any input will be appreciated
One man's driveable setup is another man's nightmare. I'm sort of picky; I really didn't want any lope, and I wanted stock-like driveability. I found, however, that to get the power and torque curve I wanted, I would have to settle for some lope and a little bit choppier of an idle. I settled on a 224/224 on a 112LSA, and it's about as big of a cam as I think I'd go with, in terms of overlap. From everything I have learned, overlap has the biggest impact on driveability and lope. I would go with a bigger cam only if it had the same overlap (ie a 228/232 on a 115). Both that cam and mine have 0 degrees of overlap. I can't speak to the driveability of the bigger cams, but I will go out on a limb and say if you are picky about how you want the car to idle and pull from a very low rpm, you probably don't want to go with a cam with a whole lot more than 0 degrees of overlap. Anything you get in the 230-240 range that will have any low-end whatsoever is going to have a ton more overlap, and thus will probably be much more ill-mannered.
The bigger duration you go, the more overlap you'll wind up with if you work to get your IVC and EVO to occur where you want them to in order to keep your powerband in a reasonably low range (you probably don't want to have a torque curve putting out 300ft lbs until 4,500rpm, and then spring instantly up to 425). As you go bigger in duration while keeping your IVC and EVO in the same spot, your LSA goes down and your overlap goes up, and your driveability at lower rpm's will decrease.
All that said, I'd think a 230-240 duration cam with Trickflow heads should be able to hit 450 easily. That 228/232 on a 115 I mentioned (that's LG's G5X1-E cam) hits an easy 450 with AFR heads, and 470 with AFR's and a FAST intake. There are several guys running that combo. A bigger cam will most likely make even more power than that, so I'd say your goals for that sized cam are totally appropriate.
The car currently has LG street headers with no cats and Borla stingers, along with a blackwing CAI.
It's funny that you should mention the LG cams; I am considering something like the G5 X3. I don't mind the lope, but I would like to maintain some low end torque. I drive the car a lot.
I agree that the HP projections are bloated a bit, and that it's all in the tune. Is anyone out there running a similar combination that would be willing to share their experience ?
All i hear is, Its all in the Tune, for streetability.
Did you do the install yourself? I have heard that the TF heads are a VERY tight fit near the Master Brake Cylinder & Power Steering pump. Any Problems? Manual or Automatic? Milage?Thanks
She does some bucking (the car) in lower gears below 1500 rpm, but is fine above that and on the highway. I've got her idling at 900rpm.
There is no real loss of torque. I can even take off at idle if I ease out the clutch. MPG is about the same as before the swap.
I started with a LG mail order tune and took over myself from there with HPTuners and a wideband. SPent a lot of time to get her where she's at. She runs in closed loop.
Good luck
You can see my sig for my mods and it is my daily driver.
And like others said, its all in the tune.
