Hmmm...put the vette away last night, started her this morning and my temperature readout is probably 1/3 the brightness it usually is. All other lights are nice and bright.
How do I fix this small but grating problem? Thanks
the resistors have finally worked themselves loose. I don't remember where but there are detailed instructions on how to fix this. it does involve pulling it apart and resoldering the resistors. this is a very common problem. search for dim auto A/C display and you will find lots of info on it.
the only good thing about all these common problems, there is so much good info here on how to fix them!
here is the thread.I need to be doing this myself as well
