Just Finished H/C Install, Code P0106?
Old Oct 18, 2007 | 09:07 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Just trust ED !
Old Oct 20, 2007 | 03:10 AM
CodeName Z06's Avatar
CodeName Z06
The car drives close to stock, but still getting used to the clutch since you need to give it a bit more gas to take off. I am very happy with the way everything turned out
My setup is:
G5x3 cam
LG Pros w/ no cats
DIY Port and Polished stock LS6 Heads
.04 cometic had to flycut .025 on the intake non on exhaust
PRC dual spring w/ hardened pushrods
LS2 time chain and LS7 lifter
25% powerbond pulley
P&P TB
Dual k&n filter (not sure that even helps)
Old Jan 29, 2011 | 11:29 AM
abelrob's Avatar
abelrob
Originally Posted by edcmat-l1
Code P0106 is pretty normal for a larger cam. It can be tuned out. Both HPT and EFIlive have P0106 min/max fail tables, that need to be adjust, because with a cam with that profile, the idle vacuum is such that the computer doesnt like it.
You dont need to turn off the code, or anything like that. You (your tuner) need to tweak the tables, setting the max fail at 0 and 10% throttle versus 800/1600 rpm, up to around 85 Kpa, where as the stock settings are something like 65 or so @ 0%/800 rpm.
Any tuner worth his weight will know this, and know how to tune it out.
HTH
Ed
Nice, after spending a grand at my tuner, they looked baffled at the P0106 code, and told me to go buy a new map sensor, there was a pointless $110. Im going to take it back to them, and hopefully they will adjust free of charge.
Old Apr 10, 2017 | 12:06 AM
Ravenrider1k's Avatar
Ravenrider1k
Originally Posted by Y2Kvert4me
The P0300 (and flashing CE light) is normal at idle for a big cam. It will be tuned out. You should not see it while driving, or holding it at a steady rpm above the choppy idle point.
If you drive the car, you will probably also toss a P0101 (MAF) code. This one is also somewhat normal for the mods you've done and should also be cured with the tune..
The P0106 is a MAP sensor code, not normal, and is one that suggests a possible intake or vacuum leak. Do you hear any odd noises (ie; whistling sound) while it's running? I know it's probably hard to tell, as it certainly sounds completely different than what you were used to.
I hear this! I have a whistling sound I have a video! Can you help me synergy told me my manifold isn't tighten all the way I assume it's because of this?
