hard to put in reverse 6spd.
Old Oct 17, 2007 | 01:31 PM
GREG O.'s Avatar
GREG O.
Default hard to put in reverse 6spd.
I replaced my 6speed about 1,000 mikes ago, and now I have a hard time getting reverse. Yesterday, I had a hard time getting it into 1st. It does not grind, just have to keep trying and it magically goes in. Does my B & M shifter need to be adjusted???
Old Oct 17, 2007 | 01:35 PM
'00FRC's Avatar
'00FRC
My stock shifter does the same thing sometimes when I try to put it in reverse. It won't pop in gear, sometimes I will have to go first to reverse a couple times and then it will go. Or I will roll the car forward or back a bit and it will go into gear no problem. I don't think anything is wrong but then again I'm not an expert. Hopefully everything is ok!
Old Oct 17, 2007 | 01:44 PM
hotwheels57's Avatar
hotwheels57
It's possible since you recently changed your shifter that the 1/4-20 fasteners have simply loosened up, causing a misalignment of the shifter.
You'll need to remove the radio surround/console trim again to check.
Use the oem shifter alignment pin from your oem shifter to maintain the shifter in neutral when you loosen the four fasteners and re-torque to 8-10 ft #.
If you didn't use any thread sealant, use a small dab of blue LOCKTITE to secure the fasteners. If you used the oem shifter fasteners, they're to short for the B&M billet base plate. You'll need to use the supplied B&M longer fasteners, or hardware grade 5 (or grade 8) 1/4-20 bolts that are approx. 1/4" longer than the oem bolts.
Also, check the condition of the two bushings under the large TORX bolts that secure the shifter above the torque tube. Those can deteriorate and/or the TORX bolts loosen. Replace those bushings if necessary and re-torque to specs.
http://forums.corvetteforum.com/show....php?t=1836867
http://forums.corvetteforum.com/show....php?t=1836079
Old Oct 17, 2007 | 01:46 PM
GREG O.'s Avatar
GREG O.
I hope it,s just a simple adjustment.
Old Oct 17, 2007 | 01:49 PM
hotwheels57
It's common for the fasteners to loosen, hence the suggestion to use LOCKTITE thread lock. I use both LOCKTITE and lock washers. I included two recent discussions of similar complaints of poor shifting or rattles, also probably due to the same issue.
Old Oct 17, 2007 | 01:51 PM
GREG O.'s Avatar
GREG O.
Thanks JW for the info. Certainly sounds like a good place to start. Good info. always appreciated !!!!!!!!!!!
Old Oct 17, 2007 | 04:24 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
I would definitely check for loose bolts and adjustment. If these are ok and you start thinking it's the tranny, I occassionally have trouble going into reverse. I picked up a hint here that shifting into second will align the bits to make it easier to go into reverse. Works every (rare) time I have trouble with reverse in my MN6.
Old Oct 19, 2007 | 02:57 PM
GREG O.'s Avatar
GREG O.
thanks Mark appreciate the info!!!!!!! btw We are almost neighbors. Nice area Fairfax. know it pretty well. just getting too conjested !!!!
Old Oct 19, 2007 | 04:12 PM
FKING1's Avatar
FKING1
My B&M is a PITA to go into first or rev. Someone is going to rearend me at a stop light because of the 1st prob. 5yrs and it has been like this from day one.
Old Oct 19, 2007 | 06:23 PM
DefenderC5's Avatar
DefenderC5
This is probably the best post I've seen on the topic. I really need to check this when I have the console off this weekend. I'm betting part of my "hurst rattle" is to blame on this. 1st/Rev sometimes take a little TLC to lock in too.
What if I do not have the stock shifter alignment pin? I adopted this C5 and it had the hurst already in it. Is there something else I can use?
Old Oct 19, 2007 | 07:05 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
I have the same problem kinda embarrassing sometimes when I back up and it grinds
Old Oct 19, 2007 | 07:20 PM
hotwheels57
You could probably use an appropriate sized nail, drill bit or drift punch to accomplish the same thing. Just make sure it fits tightly into the alignment pin hole so it's holding neutral as accurately as possible.
With a HURST or any after market shifter that has adjustable stops, you might also need to adjust the shift stops with the jamb nuts on both front and backsides. I don't know the exact clearances, but I'll bet HURST/B&M could provide that...or someone with their installation instructions.
Old Dec 1, 2007 | 10:43 PM
MAZTIFS_C6's Avatar
MAZTIFS_C6
Thats been happening to me in my 01 ALOT lately!
Even when I line up the syncros (1-2-R) I still have that light grind noise that, even with the clutch depressed, will remain and slowly taper off.
I still think I might take it in...cause its REALLY embarrassing when you feel like youre in gear and you grind 4 times in a row
-Brandon
Old Dec 2, 2007 | 12:43 AM
Bill Dearborn's Avatar
Bill Dearborn
Probably doesn't have anything to do with the shifter. You are probably getting some gear clash when trying to get into reverse and may not have gotten through all of the synchronizers on the shift to first which can be hard on a cold tranny in cold weather. Both can be handled by lightly pushing the shifter into the gear you want and slowly letting the clutch out. When the gear turns in the tranny you will feel the shifter move a little more and the tranny will be fully into gear.
Old Dec 2, 2007 | 01:01 AM
bgreen83's Avatar
bgreen83
I have the same problem to! I notice it more now since its getting really cold. I put it in first and it will go easy into reverse. I hate it, I thought it was just me. Whenever you find out what it is let the rest of us with the same symptons know how to fix it. cause it seems like alot of us have it.lol
Old Dec 2, 2007 | 03:15 AM
2blklt4's Avatar
2blklt4
Ok
I spent a lot of time investigating same problem on my `98 mn6.
The reverse gear on your C5 does NOT have a synchro period!
When tranny is cold everything is 10 times worse because fluid is thicker.
For getting it into 1st from a dead stop, go second then first.
In my opinion gear clash is the culprit in most cases that`s why wiggling the car forwards in backwards will make the shifter go in any gear most of the cases.
I think these trannies are very bulky and not very precise.
You wil NEVER have this problem with a Honda or Toyota!
Old Dec 2, 2007 | 11:35 AM
bgreen83's Avatar
bgreen83
true, and you will never have fun driving a honda or toyota... maybe a supra TT though lol
To hard to put in reverse 6spd.
Old Dec 2, 2007 | 11:41 AM
Higgs Boson's Avatar
Higgs Boson
I go to neutral, pump the clutch once, and go 3, 4, 3, 4, R quickly everytime I start the car. Slips right in everytime.
Old Dec 2, 2007 | 06:10 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
Incorrect. The factory reverse blocking ring is made up of brass. When we build our units we upgrade them to the compressed carbon lined rings. This will aid in stopping the reverse gear and keep the engagement teeth on the gear and the slider sharper. I suggest putting the shifter in 1st or 2nd gear then into reverse once the gear train is stopped.
Old Dec 2, 2007 | 06:45 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Put 600 hp through your Honda or Toyota tranny and see what happens.
