Need help found oil behind brake pedal
Old Oct 17, 2007 | 10:57 PM
rtsb's Avatar
rtsb
Default Need help found oil behind brake pedal
I was inside my car looking around and saw some oil leaking out of some boot behind the brake pedal is this something that I should be concerned with.
Old Oct 17, 2007 | 11:23 PM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Have you checked the fluid level in the master brake cylinder?
Old Oct 17, 2007 | 11:43 PM
Point & Shoot's Avatar
Point & Shoot
I see the same thing on mine. Definitely not brake fluid since the level in the MC hasn't moved.
Been there for about a year and a half - no issues.
I'll be interested to see what others think.
Old Oct 18, 2007 | 09:47 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Do you guys have telescopic steering wheel ? If so it may be leaking from drive motor.
Old Oct 18, 2007 | 10:46 AM
timemender's Avatar
timemender
Has the paint been removed at the leak area? Brake fluid will remove paint - Oil will not normally remove paint.
I can't tell from the photos if the paint has been removed or not - the more I look at the photos, the more unsure I am. My guess is that no paint has been removed.
Old Oct 18, 2007 | 09:16 PM
Point & Shoot
Never thought of that - yes I have the telescoping wheel.
Old Oct 18, 2007 | 09:22 PM
jirasvet's Avatar
jirasvet
Old Oct 19, 2007 | 04:09 AM
rtsb's Avatar
rtsb
yes I do
Old Oct 19, 2007 | 04:10 AM
rtsb's Avatar
rtsb
The paint isn't removed I have a warranty and I looked I think it will cover the problem hopefully
Old Oct 19, 2007 | 08:58 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You probably have a bad seal.
By the way there is no paint down there just rubber and sound proofing.
To Need help found oil behind brake pedal
