DRL / Turn Signal issue
Old Mar 6, 2008 | 01:59 PM
rolando.reyes's Avatar
rolando.reyes
Cruising
nice write up. i noticed that the radio has to come off. on a different subject. does the factory radio have an input jack to hook up a sirus radio on the back of it. since it was out of the dash i thought i could address my next project.
Old Mar 6, 2008 | 06:12 PM
BBaysdon's Avatar
BBaysdon
My lights did the same thing. I had acid under my battery. I replaced battery and cleaned up the acid. Check all grounds and clean. The ground is where the problem was with mine. I replaced the Hazzard switch and the Multi-switch before I found the problem. I couldn't find the bad ground so I grounded the ground plug in the front bumper on the turn signal wiring harness to the frame and the lights work great. I am still looking for the bad ground but I solved my problem.
