Suspension squeeks
Old Oct 20, 2007 | 07:27 PM
9T3JIM's Avatar
9T3JIM
Default Suspension squeeks
I lowered my 99FRC down on the stock bolts last spring and have had a squeaking noise both front and rear ever since. After a couple of miles of driving the squeaking goes away. The car has only 17k miles on it. Any thoughts what to look for?
Old Oct 20, 2007 | 07:39 PM
416 Rigby's Avatar
416 Rigby
Default So-- what alignment changes did it make?
Thinking of the same but would like to get an idea of how much it changes initial alignment
Old Oct 20, 2007 | 07:46 PM
9T3JIM's Avatar
9T3JIM
I wish I could tell you as I will be getting my 4th alignment since lowering. and we're going to compare the new alignment specs with the printout I have from the alignment in June.
Old Oct 21, 2007 | 02:10 PM
David426's Avatar
David426
Sway bar bushings are dry... Very common problem.. Easy fix..
Old Oct 21, 2007 | 04:04 PM
Corvette X's Avatar
Corvette X
what kinda lube you gotta put on the sway bars?
Old Oct 21, 2007 | 06:13 PM
9T3JIM's Avatar
9T3JIM
Thanks for the tip. I just did a search and found a thread that says to use silicone grease.
Old Oct 27, 2007 | 04:02 PM
9T3JIM's Avatar
9T3JIM
Just wanted to post back and say the problem is fixed. I lubed both the front and rear sway bar bushings today, no more squeaking, creaking, or groaning. Thanks!
Old Oct 27, 2007 | 05:01 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Best cure is to invest in some poly sway bar bushings.
To Suspension squeeks
