Relocated Oil Sensor
Old Oct 21, 2007 | 09:12 PM
jaxvet's Avatar
jaxvet
Default Relocated Oil Sensor
I just finished the oil pressure sensor relocate method as indicated in sticky above. I used copper tubing & the Buick Park Ave sensor & also extended the little vacumn line to back of manifold. Everything is great, almost, new sensor is under driver side FRC for easy future replacement, but, gauge & DIC is showing pressure about 8 to 10 lbs more than before. Is this something to be concerned about, or is the Buick sensor calibrated differently? At idle it now shows 32 or 34 lbs & at 2000RPM on road, shows 48 to 52 lbs. B/4 showed 24 or so & 42 - 44.
Old Oct 21, 2007 | 09:45 PM
jeanlucpicard's Avatar
jeanlucpicard
Remember, a guage is just a visual indicator that something either is or is not working. As long as the range is consistent I would not worry about the scale. Your oil pump is not putting out more pressure with the Buick sensor although I would have relocated my OEM sensor instead of introducing a Tiger component.
Old Oct 22, 2007 | 05:53 PM
jaxvet's Avatar
jaxvet
Thnx 4 the input, I used Buick sensor cause the body is brass & OEM units are alum & there was some discussion that that could be the failure problem area
Old Oct 22, 2007 | 07:41 PM
lucky131969's Avatar
lucky131969
That is interesting. Since it is the electronics that fails in the oil pressure sending unit causing a (typically) offscale high indication ,what difference does it make whether the body that screws into the block is made of brass or aluminum?
To Relocated Oil Sensor
