No Compression on Cylinder #7 ??
Old Oct 23, 2007 | 10:35 AM
jovette's Avatar
jovette
Originally Posted by Millenium Z06
Theres no may to it; you need to replace all the rings on all the pistons, not just that one thats not good practice.
Did you make sure you had the throttle body, fly by wire, butter fly air valve opened fully when you were cranking the engine over when performing the compression tests? You will get much lower readings if the throttle plate is not wide open.
Old Oct 23, 2007 | 10:45 AM
BonestockZ06's Avatar
BonestockZ06
No I did not do that. I wasn't aware of these facts. I suspect thats the cause of the lower readings. However, #7 was dead completely. Thanks, that makes me feel somewhat better knowing that had I done this the reading would have been higher.
Thanks for the info
Old Oct 23, 2007 | 10:50 AM
gdphillipsvette's Avatar
gdphillipsvette
Originally Posted by BonestockZ06
pour water in the cylinder, it swallowed it as fast as I poured it in. I checked all on drivers side the same way and that was the only one thirsty.
Pour water into the cylinder? I've never of such a test procedure! But if water is going through that fast, sounds more like a ring land is broken or a hole in the piston.
Gordon
Old Oct 23, 2007 | 11:01 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Gordon
I'd pull the head(s) before I started buying parts.
Old Oct 23, 2007 | 11:18 AM
BonestockZ06
The heads are off, the test was done with the heads off. It's very simple, if you don't see a whole or a crack on the piston and the head is fine, then pour something in there (water, antifreeze or oil) and wallahhh. I use to see my mentors do such things when I was a kid and still proven till this day.
Old Oct 23, 2007 | 02:29 PM
Millenium Z06
Moderator
Whats the piston and the cylnder look like?
Old Oct 23, 2007 | 02:51 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Can you post some pics of your work? We can all learn something from your experience!
Old Oct 23, 2007 | 03:02 PM
BonestockZ06
I should have it completely out by tomorrow night, i'll post the findings.
Old Oct 23, 2007 | 03:08 PM
BonestockZ06
Here are some great links for yaa.. Step by step with plenty of pictures. I followed the same exact procedures, step by step. It did help some that I been working on cars for 15+ years and have a 2 car garage with most tools needed for any job.
http://www.cajundude.com/engineswap.htm
http://www.ls1howto.com/index.php?article=1
Old Oct 23, 2007 | 10:01 PM
Millenium Z06
Moderator
Is it just the angle or does that piston look like there is no ring left on the front side of it and it's dragging the cylinder? (The front is where the dot is) Is the piston loose in the cylinder?
Old Oct 23, 2007 | 10:23 PM
BonestockZ06
It's not the angle, your observations are correct. I should have it out tomorrow. However, I guess since I caught It right away, I may have saved the cylinder wall from damage.
Since you mentioned that, I went out and looked at all 8 and they all looked identical. The side with the dot seems to have no clearance against the wall (at least not visible to the eye). So I don't think that means much.
