Replacing Coolant
Old Oct 22, 2007 | 12:35 PM
harleyvette's Avatar
harleyvette
Default Replacing Coolant
Hi Guy's
I want to drain and refill my coolant.
I do not have a hoist and my 98 C5 is lowered.
I tried to get under to the rad drain valve but cannot find it.
Could anyone give me info. where to drain?
Old Oct 22, 2007 | 12:51 PM
Kamil D.'s Avatar
Kamil D.
Default this procedure was given to my by: Oldvetter Thank you once more
Here is the whole procedure, I also posted it on your post:
Document ID# 99062
1997 Chevrolet/Geo Corvette
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
NOTICE
When adding coolant, it is important that you use GM Goodwrench DEX-COOL® or HAVOLINE® DEX-COOL® coolant. If Coolant other than DEX-COOL® or HAVOLINE® DEX-COOL® is added to the system the engine coolant will require change sooner; at 50 000 km (30,000 mi) or 24 months.
Notice
DO NOT use cooling system seal tabs, or similar compounds, unless otherwise instructed. The use of cooling system seal tabs, or similar compounds, may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
Drain and Fill Procedure
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
Park the vehicle on a level surface.
Follow the steps below to remove the radiator surge tank fill cap:
Slowly rotate the cap counterclockwise1/4 turn and then stop. Do not press down..
Allow any residual pressure, indicated by a hissing sound, to be relieved.
After all hissing stops, continue turning counterclockwise to remove the cap.
To tighten the cap, use hand tight pressure only.
Open the radiator drain ****.
Allow the system to drain completely.
Inspect the engine coolant:
Discolored -- follow the flush procedure below.
Normal in appearance -- Continue with the next step.
Close the radiator drain ****.
Important
When filling the cooling system use a 50 to 60 percent concentration with DEX-COOL® coolant.
Fill the system through the surge tank opening.
Fill half the capacity of the system with 100 percent DEX-COOL® coolant.
Slowly add clean drinkable water to the system until the level reaches to the base of the neck.
Start the engine.
Idle engine for 1 minute.
Install surge tank cap.
Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
Shut off the engine.
Refer to step 3 above to remove the surge tank cap.
Start the engine.
Idle engine for 1 minute and fill surge tank to 1/2 inch above COLD FULL mark on the radiator surge tank.
Install the surge tank cap.
Top off coolant as necessary, 1/2 inch above FULL COLD mark on the radiator surge tank.
Rinse away any excess coolant from the engine and the compartment.
Inspect the concentration of the coolant.
Flush Procedure
Important
Do not use a chemical flush.
Block the drive wheels.
Place the transmission in Park or Neutral.
Engage the parking brake.
Run the engine until the thermostat opens.
Stop the engine.
Follow the drain and fill procedure using only clean drinkable water repeat if necessary until the fluid is nearly colorless. Refer to the drain and fill procedure.
Fill the cooling system. Refer to the drain and fill procedure.
Old Oct 22, 2007 | 01:00 PM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by harleyvette
Hi Guy's
Procedure does not help much if you cannot find the drain valve.
The drain is in the lower right hand corner of the radiator and looks like a white nylon plug with a square opening. Use a 1/4" drive to turn it about 90 degrees, and the plug will pull straight out. There is a pin in the side of the plug that you have to line up with a slot in the radiator housing for the pin to come out. Don't turn it too far, or you will break the pin, and/or the radiator housing.
Note, I think Havoline may have quit making Dexcool for GM, and Prestone is now an official manufacturer of Dexcool. I noticed the local parts stores and WalMart now only have Prestone.
To Replacing Coolant
