Leak Tracer
Old Oct 22, 2007 | 12:47 PM
Tourmgr1's Avatar
Tourmgr1
Default Leak Tracer
Anyone know the name of the dye you add to oil to check for leaks and if it's available at the local auto store ?
I have a minor drip under the passenger front spring ..it's not the crank seal, possibly a power steering leak.
TIA.
Old Oct 22, 2007 | 01:35 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Never heard of a dye that you could add to your oil. There is one for an AC system.
Sorry. Hope you find what you are looking for.
Regards
The Pup
Old Oct 22, 2007 | 02:42 PM
Tourmgr1's Avatar
Tourmgr1
Maybe I just dreamed this up ....anyone ?
Old Oct 22, 2007 | 03:58 PM
bestvettever's Avatar
bestvettever
Default Oil Leak Tracer
Hi Tourmgr1, You didn't dream it up. There are Leak Tracers for engine oil, and antifreeze, as well as AC units. In fact you could add Leak Tracer to just about any automotive fluid to help find a leak. One that comes to mind is "Ultralife". There are others. Most auto stores carry them. Then after adding the tracer, you need a UV,(blacklight), light source to spot the flourescent tracer.
Good Luck..
Old Oct 22, 2007 | 04:01 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
There are test kits for checking oil leaks. Most use a dye and a ultraviolet light.
Old Oct 22, 2007 | 07:18 PM
Tourmgr1's Avatar
Tourmgr1
Thank you gentlemen.
Old Oct 23, 2007 | 10:17 AM
Benpup's Avatar
Benpup
I too apprecaite the info. I was not aware of leak checkers.
The Pup
To Leak Tracer
