driver side air warm passenger cold
took actuator out and apart.big gear was broken.bought new actuator
and installed it .
was before geting dtc codes b0367h-b0338hc-& b0361h
now driver side is still not as cold as passenger side & iam getting
dtc code b0338hc
help anybody!!!!!!
I think you have 2 seperate problems. The actuators are out of sequence and the open inside air temp sensor.
Did you resequence the actuators after you installed the new one? There are 2 ways to do this - Pull the positive battery cable off and hold it to the ground lead, and when you reconnect it you will hear the actuators cycle a few times to get properly sequenced. The other way is from the service manual - pull fuse #27 from the fuse panel in the pass. footwell, and then re-install it.
I have what seems to be the same problem you had - pass. side cold, drivers side warm. I sent you a p/m asking for help.
Thanks,
Doug
