TPS change
Old Oct 23, 2007 | 05:50 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Default TPS change
If I change my sensors, will I have to replace any o-rings or sealing washers or can I just use the existing pieces? thanks, Dave Hoping to change the batteries....
Old Oct 23, 2007 | 06:54 PM
PierEagle's Avatar
PierEagle
I hope you know there's more to it than just "changing the batteries". If you are going through all that I would use new "O" rings. They are cheaper than cheap.
Old Oct 23, 2007 | 07:52 PM
PFMC3's Avatar
PFMC3
I didnt use orings I used the stepped Gasket from a set of 2 piece chome valve stems they seem to seal better
I have been running them for 2 years on my wheels.
Old Oct 23, 2007 | 08:14 PM
Oldvetter's Avatar
Oldvetter
First you have a 2003 VERT, so you don't have o-rings, you have "gaskets".
Why are you replacing the TPSs ? You should get 10 years from them !
New TPSs should come with the gaskets. You probably should buy new TPS nuts, especially if you are going to use on another set of wheels. You could reuse yours though.
Old Oct 24, 2007 | 04:34 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
Oldvetter; I thought the life expectancy was 5 to 7 yrs. on these sensors??? built late 02 makes them qualify. No? (they are going back on the stock wheels...) if they do last ten years I'll just re-install. Dave
Old Oct 24, 2007 | 08:03 PM
Oldvetter's Avatar
Oldvetter
Series I sensors (1997-2000) have a 7 year life. Series II sensors (2001-2004) have a 10 year life, they do not report pressure in real time as Series I do. Not to worry, if you loose pressure they report immediately.
So late 02 plus 10 years equals 2012. You have plenty of life left.
Old Oct 24, 2007 | 11:37 PM
TUF-NUF's Avatar
TUF-NUF
St. Jude Donor '13
It's good to not be too old to learn. thanks , Oldvetter.
To TPS change
