Radiator fan settings: Change through DIC?
I'd like to get the fans blowing a little sooner when driving in bumper to bumper, the coolant goes up to 210-215 degrees in stop and go.
The heat build-up in the cabin will not be affected by the fans. Most of that heat comes fronm the exhaust system under the car. If you do a search for "tunnel plate" and/or "insulation" you should find several topics about things that can be done to change this.
Best thing to do is turn the AC on and direct it to your feet.
HTH, and have a good one,
Mike
BTW, wouldn't running the A/C in bumper to bumper traffic increase the load on the engine and raise temperatures even more?
* Coolant temp over 185 F
* A/C compressor is ON
* Vehicle speed LESS than 35 MPH
Then the PCM commands the cooling fans to the LOW speed setting. This helps air flow through the A/C condensor, and also keeps coolant temps down. If the above conditions aren't met, the PCM will let the coolant temp rise to 226 F before commanding the fans to LOW speed. Coolant will have to reach 235 F before th3e PCM commands HIGH speed operation.
GM Powertrain spent millions of dollars and thousands of engineering hours determining the best operating temperature for your engine, based on issues such as power, fuel mileage, and emissions. If you know better than they do, go play with the cooling fan settings.
Now the $100,000 question: Would I be stressing either the HVAC or the cooling system by running the AC in bumper to bumper WITH THE TOP DOWN? I don't but I might if it made a positive difference. Most of the time, if I'm driving the 'Vette it's because we're having convertible weather.
Thanks to everyone. If I knew better than the GM engineers, I wouldn't be asking any questions, I'd already have my answers!
But, I do know that engineers try to work compromises into their solutions, there's always room for change.
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
You can prove this to yourself ... go out to your car and start the engine. If the coolant is below 185 and the A/C is ON ... the cooling fans WILL NOT RUN. Watch your temp gauge and when the coolant reaches 185 ... voila ... you'll see the cooling fans start.
You may want to have someone check your A/C system. GM has a test facility outside Phoenix that tests cars for hot weather performance. Your A/C system should have been OK, even in those brutal conditions.
Thanks for all the info. I'm going to try running the AC when I'm creeping at rush hour and see what difference it makes. I know the old trick for bleeding heat off the engine by running the heater, but that WON'T do. If running the AC with top down isn't taxing anything (other than my wallet), I'm game. Let's not get into oil viscocity and breakdown! LOL
Actually, a hot engine with cool intake air is the best setup for HP/TQ. Want proof ?? Take a look at the engine temperatures used in race cars today. Most engines run 230 degrees on the track for max HP and Torque, with Formula1 engines (and their special fuels) running even hotter than that.
When you burn a fuel in an internal combustion engine, you are converrting the energy stored in the fuel into 2 kinds of energy. About 1/3 of the energy produced is lost as heat energy out the exhaust system. About 1/3 of the energy is lost as heat energy radiated into the engine itself (pistons, cylinder walls, heads, valves, etc.) and the remaining energy is mechanical energy that drives the piston in the power stroke. By keeping the engine parts as hot as possible, less energy is lost to heating the engine, and therefore more is available as mechanical energy.
In an "ideal" internal combustion engine the engine itself would be at the temperature of the burning fuel, which would mean you would get even more mechanical energy out of it, but with gasoline as the fuel, the engine has to be cool enough not to pre-ignite the fuel during the compression stroke.
The GM engineers (and race engine engineers) have tried to maximize the engine temp not just for emissions, but because they understand what generates power.
Hope this helps,
Hope this helps,
) we would be making a lot more power and better fuel mileage.To the op, just get a tune or a handheld tuner to lower the fan on temps.
Also for the AC question. Even with a stone cold enging, if you start the car with the AC on, the fans will come on when the head pressure is high enough to activate them........driving or not. Usually the fan wont come on right away until you start removing heat from the cabin via compressing the freon and circulating it, or high rpms with high blower speeds.
The PCM controls the fans based on engine coolant temp .... nothing else. If refrigerent pressure gets too high, the PCM shuts off the compressor until line pressure is back within the "normal" range.
The PCM is "all powerful" over the A/C compressor .... an interesting side note .... when the compressor is requested to ON by the HVAC controller, the PCM actually increases throttle on the engine to overcome the "drag" of the compressor when it first is clutched to on. That's why yoou don't feel (or feel very little) the classic "hesitation" in engine power as the A/C compressor comes on line. Pretty clever, huh ???
I've recall some members who've said they use it successfully.
