Conv. rear window
Old Oct 24, 2007 | 10:29 AM
wilburn's Avatar
wilburn
Default Conv. rear window
Has anyone had thier rear glass come out of ther convertible top? Does anyone know the fix action to this?
Old Oct 25, 2007 | 02:06 PM
waupachino's Avatar
waupachino
Many people have. I believe the glue of choice to glue it back in is Rhino Glue. http://rhinoglue.com/
Old Oct 25, 2007 | 05:21 PM
white90conv's Avatar
white90conv
I think you can find a post of instructions to repair the window.
Old Oct 25, 2007 | 06:10 PM
99 vett babycar's Avatar
99 vett babycar
most convert top places can re-glue it for you
Old Oct 25, 2007 | 07:23 PM
BATM4N's Avatar
BATM4N
I have a copy of what your looking for Let me see if I can get a copy on here. I got it from here but the thread doesn't show anymore.
Old Oct 25, 2007 | 09:51 PM
BATM4N's Avatar
BATM4N
Convertible Rear Window - How to Refasten:
My 2001 convertible is my everyday car. I drive it in rain, snow and good weather. It is and always has been garaged. Three weeks ago at about 128,000 miles the back glass window separated from the top. The separation first started at the top and when it got to the sides and started separating at the bottom I stopped driving it.
I’ve done lots of research on this site and others (including BMW, Audi and other convertible top postings). The results are that upholstery people usually say the sealing process is high pressure done under heat at the factory and there is no way to duplicate it in the field so you have to replace the top. Estimates for top replacement range from lows in the area of $500 to $1000 to a high of $3000 with the average being $1000 to $1500.
Some people report glue attempts with total failures after days or weeks. Others report glue success and the glue holding after much longer times.
Those reporting glue success used a variety of glues including: JB Weld, Black silicone RTV sealant, pure clear silicone sealer, 3M high black weatherstrip adhesive, and urethane windshield glue. One person posted that he used a cyanoacrylate glue that he got at a hobby shop. Super glue and its various other names are cyanoacrylate glues.
I did my own research and settled on Rhino Glue which is a specially formulated cyanoacrylate that is waterproof, weatherproof and completely resistant to heat and cold. See www.rhinoglue.com for more information.
I was not able to find this glue in any store and bought it online. This is a totally different glue than Liquid Nails Rhino Ultra Glue. Do not buy the Liquid Nails kind.
Here are pictures of what the separation looked like before I started gluing.
The first one was taken when the separation first started. Compare it with the ones below with the suction cups and you can see the progression of the separation down the side with just a little more driving.
My advice is to catch it before the window comes completely loose.
These round red things are suction dent pullers.
I found these online. They come in a 1, 2, 3 or 4 suction cup variety. www.cvfsupplycompany.com/sucusucupdep3.html. I bought the 4 cup variety without thinking. I got 2 of them (only needed one in the end) for $30 and that included the shipping. When they arrived, I realized that they were too large for the window so I cut them in half. A better choice would have been either the 2 cup or 3 cup ones. I then rigged up a way to pull them so that the glass would be pulled against the fabric. You can see that this simply involved screwing an eye into the rafter above.
I then applied the glue around the glass about 3 to 6 inches at a time. Be careful and test this out before you apply the glue. I made the mistake of starting on the sides and moving toward the middle and was left with a significant bunching at the middle. The glue set up so fast that I actually had to cut the top away from the glass at the corner to smooth out the bunching. At the finish of the job, I was still left with a little bunching at the drivers side. As I’m not a perfectionist and it isn’t very noticeable, I haven’t tried to correct it.
This is the finished job before I removed the dent pullers.
I did the job at 7 PM and left the suction cups attached until the next morning at about 8 AM. I then drove the car to an automated carwash which I figured would be a great test for the bonding strength. It came through with flying colors - no separation of the window from the top and no sign of leaking.
I then drove it 50 miles with no sign of any separation.
If the glue is as advertised, judging by the part I had to remove and redo, I expect it will hold up for a very long time
Old Nov 5, 2007 | 01:33 PM
tawc5's Avatar
tawc5
Thanks for taking the time to place this posting. I duplicated your work with little problem, thanks to the great instructions. Window seems to be tight. One side benefit, over the years the wind noise had gotten much louder, probably because the top was coming unconnected. Now considerably more quiet. One additional suggestion is to cover the body under the window with paper before glueing. I failed to do so and some leaked down to the gasket. Now another problem to fix that could have been avoided.
Old Dec 15, 2007 | 12:45 PM
cubelets's Avatar
cubelets
6th Gear
I had the same problem with my 2001. I ordered the Rhino glue and it worked fine, in the meantime a poor man's solution is to grab two way tape at home depot (the white spongy kind in the paint section) while waiting the week for the rhino glue to come in it only took 20 minutes to put in place then I used a broomstick with a towel against my dash and the window to hold it in place, seeing the white bothered me so I grabbed a black marker and TA DA it looked fine.
Old Jan 4, 2008 | 05:54 PM
Crankin's Avatar
Crankin
6th Gear
Great, thanks for the all the information...I'll have it ready to go before the snow melts!
Old Jan 4, 2008 | 06:03 PM
BATM4N's Avatar
BATM4N
Glad this worked out for you guys When this post first got started I did a search and couldn't find it Luckily I had saved it on MS Word for some reason
Old Sep 16, 2008 | 10:02 PM
smace's Avatar
smace
How long has this held for you guys. I called a bunch of top places today and of course they wanted to sell me a top.
Old Sep 17, 2008 | 01:42 AM
white90conv
I found a product at a local woodworker's tool shop. It is cyanoacrylate glue with a thickener and I suspect it is the same as Rhino glue, but it is available locally. It is called "Hot Stuff Super T".
I had only a section on one side that had come loose and I repaired it and it appears to be very strong. However, I got some of the glue on the fabric of the top and it left a permanent mark. I was holding the top and the window together with tape and the glue oozed between the tape and the fabric top. Be careful.
Old Sep 17, 2008 | 08:13 AM
rws.1's Avatar
rws.1
Old Sep 17, 2008 | 11:11 PM
smace's Avatar
smace
Sounds like it is going to be fun to fix. Lets hope it holds for a good long time. Would be Silly to replace a top that looks like it came off the show room floor.
To Conv. rear window
