Codes??????Please Help!!!
Old Oct 24, 2007 | 04:12 PM
Clintny25's Avatar
Clintny25
Default Codes??????Please Help!!!
I had these codes Please tell me what You think I need to do to Fix all the Issues..
P1637 H C Generator L- Terminal Circuit
P1638 H C Generator F- Terminal Circuit
HVAC Codes----
B0338 H C Air Temp sensor circuit
B0361 H Hvac Actuator Feedback Circuit
B0367 H Same as teh B0361 Code
LDCN Codes----
B2252 Door Key Cylinder Circuit
Please Help me figure what is up with the Car and what parts are going Bad???
Old Oct 24, 2007 | 06:53 PM
jirasvet's Avatar
jirasvet
IMO you need to clear them and see what comes back.
Need to check all grounds and battery connections.
Read the electrical sticky for ground locations.
Most common annoying code for the HVAC. There is a write up
about re indexing the actuator.
Need to check the connections at the ambient air temp sensor,
and the inside air temp sensor.
Need to check for lose or corroded connections at alternator
and the PCM.
Possibly the voltage regulator is going bad in the alternator.
Need to check the connector harness in the door. Check out
DIY sticky for pics on LDCM
