Raning lean
Old Oct 25, 2007 | 07:31 PM
titoc6r's Avatar
titoc6r
Default Raning lean
2004 coupe the car rans good stock when i ran it with the programmer or nos it leans out bad any ideas
Old Oct 25, 2007 | 10:42 PM
bgreen83's Avatar
bgreen83
not sure, but do you have it programmed to run rich when you spray? spraying leans out the mixture
Old Oct 26, 2007 | 05:51 PM
titoc6r's Avatar
titoc6r
its a hyper tech programmer i cant programmed it to run rich
Old Oct 26, 2007 | 06:26 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
With spray, get a dyno tune. The HT tuner is only going to give you a generic tune.
Old Oct 26, 2007 | 11:32 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
ewww!
To Raning lean
