spark plugs....01 coupe
Old Oct 25, 2007 | 09:22 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default spark plugs....01 coupe
does anyone remember what sparkplugs were installed in 01 corvettes?
mine has NGK v-groove vr55 plugs in it.
I have saved the factorysparkle plugs out of my 01 Tahoe and for comparison, they are platinum, but the NGK plugs don't look like platinum, they look like regular steel with the normal center electrodes with a dent in the center electrode to resemble a v....not platinum.
Anyone?
The reason I'm looking at these, is there is a tick tick in the radio that speeds up and slows down with the RPM of the engine, but only on weak radio stations. It sounds like the ignition bleeding through into the radio due to a bad plug wire. I got to the #7 spark plug, and the little screw-on top on the spark plug was loose and had backed off about 3 threads. I was thinking since i was into it, I would put platinum plugs in it, but if the NGK plugs are any good, I'd leave em in. The car has 34,000 miles. Other than that, it's been an absolute trouble-free car except for the reverse switch shorting out.
Old Oct 25, 2007 | 09:30 PM
Mike Mercury's Avatar
Mike Mercury
Denso Iridium... I believe.
Old Oct 25, 2007 | 09:36 PM
coupeguy2001
Default plugs
so someone was in there and changed them out before I got it I guess. They don't look worn at all.
To spark plugs....01 coupe
