Please help!!! headlight problems :(
Turn on your high beams and then close. The circuit of the new HOD's has the wrong resistance and causing the problem.
Also, every time I turn the lights on, fogs or lows, it would reset my laptrax, as if it thought the ignition had been cycled...
I'm officially stumped. Any ideas?
Your HID Fog lights are probably drawing to much current and you'll need to run directly from the battery, just like the PIAA's.
Thank you, and we'll see where we get.
Check relay #39 under the hood.
Do you have approach light selection on when you hit the key fob. If not turn it on and see if they light up at night.
If they don't you'll need to start tracing the circuit to see if it's a power or ground problem.
I would see if there is another similar relay and see if that works, first before trying to directly connect up to the battery.
I would also check fog light wiring to see that it is not melted.
Does the light in the fog light switch light up when you turn them on ?
When in doubt, I always stick in a fresh fuse to test as it sometimes diffcult to visually tell if the fuse has been blown.
Additionally, the labeling on the fuse box is not great. I had similar problems when I did a conversion from an auto to six-speed as the tranny harness wire also has the wiring for the rear turn signals, rear lighting, etc..
When I finished the swap, I had no instrument lighting, rear light, fog lights, parking lights, etc. The only thing that worked was my headlights.
Turned out that one of the wires in the terminal block was loose in the passenger footwell, that I had probably hit when I was sliding wires in and out of the firewall in that area when I was doing the re-wire job for the six speed.
It had me stumped for a while, but then I just systematically went thru each wiring schematic and did my due diligence. As usual it turned out to be the last circuit that I checked being the culprit.
A quick re-crimp of the terminal end that was causing the problem and presto it was fixed.
Only problem left is to figure out why my alternator keeps giving me low voltage 12.3 vs that across the battery.
