Installed HUD .. Broke car
Old Oct 29, 2007 | 02:48 PM
Kleago's Avatar
Kleago
5th Gear
Default Installed HUD .. Broke car
Installed HUD in my car today. Everything went great until I tried to take it for a test drive. When I started the car my display said REMOVE KEY, WAIT 10 SEC .. SO I did. Now my display says SERVICE COLUMN LOCK and the car dies if I try to move. Any ideas what I broke or how to fix it? My dealer said they did the lock recall, but somone said it could be from the recall. Any advice would be great... thanks
Old Oct 29, 2007 | 02:55 PM
plaster's Avatar
plaster
Lots of info on this - check the first sticky topic at the top of this section.
Apparently the GM recall doesn't work very well there's a product that does not allow the column to be locked that does work.
You can free the wheel by turning th ekay on and pulling hard to left or something like that - there is detailed info once you search.
Don't feel bad as it's not really your fault or anything you did.
Old Oct 29, 2007 | 03:02 PM
LETHL_C6's Avatar
LETHL_C6
If the recall has been done, locate the K harness they installed and remove it.... car should be fine then. The harness the dealer installed in mine went bad and caused the same thing. I used EFI Live and just turned off the system after I pulled out the harness.
Old Oct 29, 2007 | 08:23 PM
spr95skt's Avatar
spr95skt
So, the installation of the HUD and not starting was not related?
Old Oct 29, 2007 | 08:42 PM
corvettedoug's Avatar
corvettedoug
Probably not. The column lock can happen at anytime. I would imagine it was just a coincidence.
Old Oct 30, 2007 | 10:31 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
And a CLB should be your next project.
Old Oct 30, 2007 | 11:12 AM
lp2k's Avatar
lp2k
You guys have no idea how much pure coincidence finds me
To Installed HUD .. Broke car
