Heater/Cooling Control Nozzle?
Old Oct 29, 2007 | 04:54 PM
RrCoX22's Avatar
RrCoX22
Default Heater/Cooling Control Nozzle?
Where is this located in the engine bay? I believe the car is giving off a hell of a lot of heat and the *** needs to be checked. I actually think its broken as from the inside (interior) when the temperature **** is turned it moves freely as if its not even connected.
Old Oct 31, 2007 | 09:14 PM
RrCoX22's Avatar
RrCoX22
no one knows where the heater/cooling temperature valve is located in the engine bay?
Old Oct 31, 2007 | 09:35 PM
LoneStarFRC's Avatar
LoneStarFRC
Heat/cool **** is electrical, not mechanical. A damper door gets moved electrically to allow/restrict air flow to heater core by the blower motor. That's why your **** feels so smooth. It's only allowing an electrical motor to position the damper door position. Hot water circulates all the time in the heater core.
HTH
Old Oct 31, 2007 | 09:44 PM
Bill Dearborn's Avatar
Bill Dearborn
There isn't any. The heater gets hot water all the time. They control temperature by controlling the amount of air that goes through the heater. Run the On Board Diagnostics and see what codes you get as you could have a problem with HVAC actuators that control the air flow.
Here is the diagnostic for the automatic air conditioning (assuming you have the automatic version):
Too Hot in Vehicle
Test Description
The numbers below refer to the step numbers on the diagnostic table.
2. This step clears the HVAC control module memory and checks for current air temperature actuator diagnostic trouble codes.
3. Ambient air temperature must be above 3°C (38°F) in order for this A/C Compressor test to be run.
7. The specified values are from the A/C System Performance Test
Step Action Values Yes No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
DEFINITION: The temperature cannot be adjusted, or the cooling is insufficient during A/C operation.
1
Did you perform the HVAC Diagnostic System Check? -- Go to Step 2
Go to Diagnostic System Check - HVAC Systems - Automatic
2
1. Recalibrate actuators. Refer to Re-Calibrating Actuators .
2. Install a scan tool.
3. Turn ON the ignition, with the engine OFF.
4. Observe the Diagnostic Trouble Code (DTC) List in Heating and Air Conditioning.
Does the scan tool display any DTC B0361, B0363, B0365, B0367, B0441 or B0446? -- Go to Diagnostic Trouble Code (DTC) List
Go to Step 3
3
Important
Ambient air temperature must be above 3°C (38°F).
1. Cover the sunload sensor.
2. Start the engine.
3. Fully open all panel outlets.
4. Adjust the temperature control to maximum cooling.
5. Select PANEL (upper) mode.
6. Adjust the blower speed to maximum.
7. Ensure that the VENT (outside air) mode indicator is not illuminated.
Does the A/C compressor operate? -- Go to Step 4
Go to HVAC Compressor Clutch Does Not Engage
4
Place the blower motor switch in each speed position.
Does the blower motor operate correctly for each speed position? -- Go to Step 5
Go to Blower Motor Inoperative
5
Does the blower motor provide sufficient air flow? -- Go to Step 6
Go to Blower Motor Malfunction
6
1. Place the blower motor switch in the maximum speed position.
2. Place the mode switch in the bi-level position.
3. Place the outside air switch in the ON position.
4. Place the recirculation switch in the ON position.
Does the recirculation door operate properly? -- Go to Step 7
Go to Air Recirculation Malfunction
7
Perform the A/C system performance test. Refer to Air Conditioning (A/C) System Performance Test in Heating, Ventilation and Air Conditioning.
Does the system pass the A/C System Performance Test? -- Go to Step 8
Go to Air Conditioning (A/C) System Performance Test in Heating, Ventilation and Air Conditioning
8
1. Install a thermometer near the inside air temperature sensor.
2. With a scan tool, observe the Inside Temp Sensor data parameters in the Heating and Air Conditioning data list.
Does the scan tool indicate that the sensor temperatures are within 3°C (5°F) of the thermometer temperatures? -- Go to Step 10
Go to Step 9
9
Inspect for a blocked or malfunctioning inside air temperature sensor. Refer to Inside Air Temperature Sensor Replacement .
Did you find and correct the condition? -- Go to Step 20
Go to Step 13
10
1. Turn the engine OFF.
3. Cover the sunload sensor.
4. Start the engine.
5. Adjust driver side temperature to 22°C (72°F).
6. With a scan tool, observe the Sun Load Sensor data parameter in the Heating and Air Conditioning data list.
Does the scan tool indicate that the sunload sensor parameter is greater than the specified value? 4.3 V Go to Step 11
Go to Step 15
11
1. Uncover the sunload sensor.
2. Direct a light source at the sunload sensor.
Does the voltage change? -- Go to Step 12
Go to Step 15
12
Does the customer need to change the set temperature frequently to maintain comfort? -- Go to Symptoms - HVAC Systems - Automatic
System OK
13
Inspect for poor connections at the harness connector of the inside air temperature sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 14
14
1. Turn OFF the ignition.
2. Test the inside air temperature sensor resistance. Refer to Sensor Resistance Table .
Does the resistance measure near the specified value? -- Go to Step 16
Go to Step 17
15
Inspect for poor connections at the harness connector of the sunload sensor. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 18
16
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 19
17
Replace the inside air temperature sensor. Refer to Inside Air Temperature Sensor Replacement .
Did you complete the replacement? -- Go to Step 20
18
Replace the sunload sensor. Refer to Sun Load Sensor Replacement .
19
Important
Perform the recalibration procedure for the HVAC control module.
Replace the HVAC control module. Refer to HVAC Control Module Replacement .
20
Operate the system in order to verify the repair.
Did you correct the condition? -- System OK Go to Step 3
Bill
To Heater/Cooling Control Nozzle?
