I need to get a service manual for my 2001 C5. In the meantime, is there anyone out there that can look up the Fuel Trim Cells for 2001. Normally it has been cells 1-19 for accelleration, 20 for idle, 21 for decelleration, and 22 for WOT. I think that GM may have made a change for 2001. I have been logging Ease Scans and using a MAF Translator to adjust LTFT's. It seems that at idle, Fuel Trim Cell 19 is the cell that's registering. If this is the case, my LTFT's are off, because I have been including Fuel Trim Cell 19 in my averages. If someone could confirm the FTC's for 2001, it will be greatly appreciated. Thanks, Eric
Re: Technical question. Fuel Trim Cells 2001 C5 (oceanaire)
18 = Idle - AC On
19 = Idle - AC Off
20 = Idle Warm-up
1-17 are not all acceleration as the lower cells are also used for cruise conditions. For your averaging purposes, you may want to include idle (18, 19) as well.
