Is there more than one oil pan gasket? I took my 03 AE for a oil change today. It only has 11,000 miles on it. After getting home I noticed this upper gasket leaking on my invoice. No one talked to me in person about it. This was kinda strange to me as the car has never used any oil or left any oil on the garage floor. What do you make of it?
I had to have my oil pan replaced and the pan itself I believe was around $900 for the part. In order to install it they had to remove a good portion of the front end and required an alignment afterwards. It was Very expensive. I hope yours isn't the same situation. If it isn't leaking any oil on the floor and is meerly 'Seeping', I would wait for it to get worse before I'd spend the money. Find out more specifically what they meant and possibly have it put on the rack to look at it yourself. Mine was leaking enough to drip about 1 qt oil in about 2500 miles. The only reason I had them fix it was becuase they were going to fix the rear main seal while they were already in the bell housing after I blew up the clutch. It was kind of a domino effect in fixes. Good luck - Ron
