Tsp224r
1. Does it shake at idle? Not much. It does shake a little, but it's not obnoxious.
2. Does it surge? Not at all. The only difference I have noticed is that at sub-1,000 rpm, the rpms will drop a little quicker than stock, but if it's in gear, it will pull at 1,000rpm just fine. Gas mileage hasn't gone down either.
3. How much valvetrain noise? There is some with this .581 lift cam, but it's not that bad, to me. With the windows up and no radio on, you can hear a sound like cicadas. It's actually not that noticeable standing next to it.
4. How fast is it? I ran it at the track one time, and I ran a 12.4x at 117.4mph. This was the first time I had ever tried to launch it after getting the new setup, and was with runflats, and I bogged the launch. I think the mph is indicative of how it pulls more than the time. I should have run quite a bit better time.
Let me know if there are any specifics you'd like me to answer...
Edit: How dumb could I be? I didn't put in the dyno graph or sound clip. Here they are... Doh!
VRX3 226/228 .585/.588 on 112/113/114 lsa for my cam in my 99 coupe. Although i plan on keeping stock stall since its a pure street car it will be 114lsa for me. Just cant pick heads to put with it would stock ls6 z06 heads be a waste of 600 bucks?
http://www.ls1tech.com/forums/showth...es#post6184062
the stock 241, 243, 862(5.3L) heads. Anyone have them?
