Front wheel bearing replacement, how tuff?
Old Nov 1, 2007 | 08:22 AM
Sethmo99's Avatar
Sethmo99
Default Front wheel bearing replacement, how tuff?
I'm getting a serious vibration in the front drivers side, thinking I've got a dead spot in the wheel bearing, or simply dried out? Car just turned 130k, how tuff of a install is it?
Old Nov 1, 2007 | 09:21 AM
flir_man's Avatar
flir_man
There are numerous wear out items that would cause a vibration in the front of the car. The bearing is not one of them. With today’s hardening and precision, bearings last almost forever. Check your tires and balance, tie rods, and bushings first.
Old Nov 1, 2007 | 10:02 AM
Sethmo99's Avatar
Sethmo99
Its not actually a vibration its more of a continous grinding but with no sound, its as if something is out of sync. It can't be felt on the passengers side, just the drivers?
Old Nov 1, 2007 | 10:17 AM
Bandit 00C5's Avatar
Bandit 00C5
2023 Corvette of the Year Finalist - Modified
2022 C5 of the Year Winner - Modified
It may or maynot be the bearing. The C5's use a hub assembly which means the bearing and the hub are 1 unit. Easiest way to check is to remove front wheel, caliper, rotor, and grab the wheel studs. Move them back and forth and spin the hub to see if it wobbles at all or is hard to spin. If it is then time for a new hub assembly which is very easy from that point.
Old Nov 1, 2007 | 10:26 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
they wear out somewhat often at that mileage
Autozone/Timken $160 for fronts
T55 Torx for the bearing bolts
6mm internal wrenching 3/8" bit and 21mm wrench to remove the nut on lower ball joint
Easy job, about an hour, here's a pic of the lower/upper/knuckle rem'd from vehicle
if you have any questions, post or pm
Old Nov 1, 2007 | 05:45 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Check the brakes first. Make sure you're not dragging the inner pad, for example.
Assuming it's the bearing (I've replaced all four of mine), it's an easy job, it just requires some brute force to separate the ball joint and pull the entire hub assy.
I would not pull the whole upper/lower control arm assy because it'll probably ruin your alignment.
Old Nov 1, 2007 | 05:49 PM
SteveDoten's Avatar
SteveDoten
neither would I, just had the pic as a helpful aid
Old Nov 2, 2007 | 08:00 AM
Sethmo99's Avatar
Sethmo99
Thanks guys, once agian no labor charges thanks to the corvette forum!
Old Nov 2, 2007 | 08:54 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Lift the car and see if you can pull the wheel towards you. If you can move it in and out then chances are it is the hub.
I just replaced mine. We wanted to see how long it took to do it in the common garage versus the shop so 2 friends came over and we followed the repair manual. The manual was a great aide and it took us 2.5 hours which included hunting for the right tools.
Things you might not have, but need; a ball joint seperator, a good torque wrench and torx 50 or 55 I forget
Here are some pics
Old Nov 2, 2007 | 09:45 AM
Sethmo99's Avatar
Sethmo99
Great pics! Thanks
Old Nov 2, 2007 | 11:33 AM
BATM4N's Avatar
BATM4N
Old Nov 2, 2007 | 05:41 PM
Tex_Vette's Avatar
Tex_Vette
Just Passin' Thru
And just to add to the posts above, Jake Latham has a couple of write-ups with pics on the full replacement of front or rear hubs. Check it out:
http://www.jakelatham.com/C5/misc/
HTH!!
Tex_Vette
To Front wheel bearing replacement, how tuff?
