Headlight doesn't operate properly after gear install
Old Nov 1, 2007 | 10:31 AM
Kale's Avatar
Kale
Default Headlight doesn't operate properly after gear install
Installed the franker gear. Let the epoxy sit for 3 days before installing the motor assembly back in the car. Worked fine for a few days, then the headlight would intermittently not come up. Then it wouldn't come up at all. I found if I used the manual dial on the actuator and turn it counterclockwise a few turns, the headlight would start operating normally for 3-4 uses. But it always stops working again.
Any suggestions?
The gear casing is intact, glue has not failed.
Old Nov 1, 2007 | 11:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
is the light turning on and just staying down? do you hear anything from the motors when you turn the switch?
Old Nov 1, 2007 | 11:29 AM
Kale's Avatar
Kale
It turns on. It just goes "urgh." and stops.
Old Nov 2, 2007 | 10:30 AM
Kale's Avatar
Kale
bumpalicious
Old Nov 2, 2007 | 03:23 PM
Oldvetter's Avatar
Oldvetter
Did you use the lube that was supplied. If you did not, shame on you, you will have to take apart and lubricate the gear.
Old Nov 2, 2007 | 06:21 PM
Kale's Avatar
Kale
No lube was supplied. (or instructions)
To Headlight doesn't operate properly after gear install
