Gas Cap Locking Door
Old Nov 1, 2007 | 09:46 PM
JOEY P's Avatar
JOEY P
Default Gas Cap Locking Door
Were can I find the gas cap lid lock.....It keeps sticking and the lid will not stay closed.....Also how to install it.......Thanks.
Old Nov 2, 2007 | 09:00 AM
JOEY P's Avatar
JOEY P
Can anyone answer this.
Old Nov 2, 2007 | 10:09 AM
Kamil D.'s Avatar
Kamil D.
http://www.pfyc.com/pc/GN1024/VTNEW/...+Gas+Caps.html
Old Nov 2, 2007 | 12:34 PM
JOEY P's Avatar
JOEY P
Not the cap itself the outside cover that has to open to get to the gas cap.
Old Nov 2, 2007 | 12:56 PM
LoneStarFRC's Avatar
LoneStarFRC
You're going to have to remove the LR wheel well housing to access it for replacement.
HTH
BTW, 10275633 is the actuator part number.
Call 1-800-234-5284 Fichtner Chev (forum vendor) Ask for Bob in parts. Just be sure to let him know you are a forum member.
HTH
Old Nov 2, 2007 | 04:46 PM
NITRO UK's Avatar
NITRO UK
Give the little black pin a spray of wd 40 or silicon ,
then give the switch a good workout. well you never know.
Old Nov 2, 2007 | 10:27 PM
LoneStarFRC
Wouldn't hurt. There's a return spring on the plunger (pin) inside that may be corroded (from water, moisture, etc). That spring is what holds the pin in the "out" position to allow the door to latch. It also could be broken though.
Old Nov 3, 2007 | 11:35 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Joeyp -
I have a how-to in my website -
http://www.iammoon.com/c5tech/fuel_filler_door.htm
As someone said, what happens is that the pocket that the plunger spring resides in collects water from washings etc and the spring rusts away to nothing.
You can buy a spring assortment at home depot or lowes etc for a couple of dollars and replace the spring.
Easy and you do not have to spend $100 on the whole release mechanism unless you really have a problem with that assembly (not likely).
best regards -
mqqn
Old Nov 3, 2007 | 06:10 PM
JOEY P's Avatar
JOEY P
You guys are great.....Thanks for all your help....
Old Nov 3, 2007 | 06:16 PM
LoneStarFRC
Let us know how it turns out.
Old Nov 12, 2007 | 01:43 PM
JOEY P's Avatar
JOEY P
This took me about one hour to make the repairs.....Just as you said when I opend the plunger the spring was in pieces......The spring kit I bought was from home depot.....If you need to do this....You need to look in the hardware section at home depot for the springs they sell a multipack of springs for 3.50........ Again I wanted to thank everyone who replied to this thread.....Its guys like you that don't let pepole ROB us on fixing these cars as soon as they see a corvette.
Again Thanks you guys and girls on this site you are awsome.
Old Nov 12, 2007 | 01:56 PM
NITRO UK's Avatar
NITRO UK
EXCELLENT!
Old Nov 12, 2007 | 01:58 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
mqqn (andy) that is quite a post and I really appreciate it
Guys like you are the true "spirit" of the forum
Old Nov 12, 2007 | 06:17 PM
rws.1's Avatar
rws.1
mine would only open and close with the button in the console... when I found out it should close by just pushing the door closed, I sprayed the plastic pin with WD 40 and manually depressed it several times...
That was 2 years ago... I have recently noticed the door is getting a little stiffer to close...
I guess it is time for another shot of WD 40
To Gas Cap Locking Door
