HVAC - Is this normal?
Old Nov 2, 2007 | 09:41 AM
richieice's Avatar
richieice
Default HVAC - Is this normal?
I have auto HVAC on my 98. Drove to work this AM and the outside temp read 43 degrees. All the way to work, regardless of me changing the interior temp from 68 - 80 the A/C light stayed on (no blinking just on). As I moved the interior temp around I watched the vents change from defrost to under the dash..still no change. The heat works perfectly. The temp was great and fan speed was responding great to the temp as I moved it around. Any ideas?
Old Nov 2, 2007 | 09:43 AM
Robls6's Avatar
Robls6
Mine does the same thing.
Old Nov 2, 2007 | 09:49 AM
clif's Avatar
clif
St. Jude Donor '09-'10
That is the same question I have! Why does the AC stay on when the setting is 80, and the outside temp is 40?
Old Nov 2, 2007 | 11:45 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The system looks at a combination of sensors such as the outside and the inside temperature to determine how much heat and how much cooling is needed to keep the inside at the selected temperatures. Yes, it runs both the heating and cooling simultaneously to do this. The compressor will shut off when the BCM commands it to do so and that usually happens between 38 and 43 degrees F, outside temps. I will venture a pure guess here that its software decision process is based upon temperature changes over a short amount of time and if the two temperatures (Inside and Outside) remain stable or not.
Old Nov 2, 2007 | 01:34 PM
RyanR0101's Avatar
RyanR0101
That auto dual zone climate control sucks. I like the manual system in my Grand Am better! I don't know why they can't just leave well enough alone sometimes....
Old Nov 2, 2007 | 03:34 PM
BlackZ06's Avatar
BlackZ06
RTFM ....
Your A/C will be on any time the system is set to AUTO unless the outside temperature is between 35 to 40 degrees. If the outside temp is below the minimum amount, the A/C button will flash if you attempt to engage A/C in MANUAL mode.
The HVAC controller uses the A/C system to de-humidfy the air before warming it and sending it into the vehicle cabin. This reduces the chances of the windows fogging on a cold morning.
The GM HVAC system is considered one of the best in the world. You almost never see an auto magazine even mention it because it is so good it goes virtually unnoticed. Put in AUTO mode, set the temp you want, and enjoy what it can do for you. The software behind it is quite sophisticated, even with features such as when the HVAC controller requests the A/C compressor ON, the PCM (which actually controls the compressor) throttles the engine up slightly at compressor engagement to minimize the feeling you get in many cars of a hesitation in engine power as the compressor comes on line.
Old Nov 2, 2007 | 03:50 PM
richieice's Avatar
richieice
Amazing. Thanks a lot! Love it when you think something is broken to find out it is superior. Makes sense because I read a few other posts which talked about removing humidity. Appreciate all the feedback.
To HVAC - Is this normal?
