Error codes......help!!!!!
Old Nov 18, 2001 | 01:59 AM
Blacked-out's Avatar
Blacked-out
Default Error codes......help!!!!!
Help, :cry :cry
I am putting together a 98 coupe and was hoping someone can give me tips on 2 error codes Iam getting.
I reset all error codes and 2 would not clear they are b0338hc, b2285h
B0338HC is a Inside air temp sensor (History, Current)
B2285H is a Battery fault #2 (history)
The passenger door window/lock does not work (switch does lock/unlock driver side door)
Any help is greatly appreciated.....I hate to take it to the dealer, electrical gremlins are big$$$$$$
:D :D
Old Nov 18, 2001 | 05:52 AM
tfinzel's Avatar
tfinzel
Cruise-In II Veteran
Default Re: Error codes......help!!!!! (black_c-5)
If you still have the stock battery, I would ditch it and get an optima. A lot of electical gremlins can be caused by a failing battery
[Modified by tfinzel, 4:52 AM 11/18/2001]
