Turn the key to on. You don't have to turn the car on. Press and hold the options key and press the fuel button 3x. This will put you into diagnostic mode. you can use option and the button above it to scroll through the codes and if you press and hold reset you will be able to clear them. You'll figure it out it's really simple.
