I currently have an 03 Z06 and just trying do things right the first time. My goal is 525/500 on motor. I'm trying to figure out what is the best cost effective way to go. I know what parts I need but is it cost effective to go to a 402? I figure I could go to a 383 with forged internals for about 5k. Then again I could get a LS2 402 for about 6500-7k and then just sell my z06 motor and make money back there which would actually be better than the 383. But if I can't reach my goal with the 383 then it is not an option. Need good advise with details on what the setup would consist of for either way. Thanks.
The bigger the motor, the easier it is to make power.. Plus, with the 403 you have the benefit of the larger bore, which helps the heads breathe better.
Ed is absolutely correct. The bigger bore offers more head choices and less valve-shrouding. The price difference between the two doesn't justify the 383, so just go with the 402. BTW, I have a LSx 383 in my Z28, so take that for what it's worth...
Agreed... I went the 383 route, and while I love it, I wish I went with the 402. The plan is to pull it while it still has relatively low miles on it and I can still get good money for it, and drop in a 402-427.
Being that all that is said what would be a good Forged 402? Pistons, Rods, Crank & Heads to reach my power goal?
LS2 block, eagle rotating assembly, or comparable, and take your pick of the leading head companies. I prefer ETPs. Just preference, the other companies are good too, I just believe in the reduced valve angle. If 15* is good (stock LS1) and 13.5* is better (TFS) then 11* has to be best (ETPs)
You might as well go with a stroked LS3= 415
Would not cost much more than a 402 and why not?
Use ported L92/Ls3 heads and you should get to your goal with tons of torque and good manners.
What exactly is the LS3? I've seen some mention that its a L92 is that correct or what? Is it a GM block? Who carries the LS3?
The LS3 is a 6.2 litre L92/L76 engine in the 08 Vette. Pretty cool setup. Seems the engineers are taking a que from the hot rodders, tuners. Bigger motor, L92/L76 setup.
Love the results we get with the L92/L76 heads/intake. I also agree with the 402-408. Good value for the $ with great reliability and power throughout the power band.
OK, that clears some things up. I have seen some L92 short blocks around, but did not know that it was called a LS3 as well. For those of us on a budget would an existing set of LS6 heads work? I know they are not optimal, but using existing heads could put off a chunk of change for a while
What about storkers? Is it a crank change? I've also read in a couple of places that when you have a stroker you have to refresh the rod bolts more often because of the higher piston speeds.
Go 402 and don't look back........ I love mine. I had actual ordered a 383 and changed my mine during the process and payed the extra money. I'm glad I did and you will be too.
