BCM Pinout
Old Nov 6, 2007 | 02:55 PM
weinerschizel's Avatar
weinerschizel
Default BCM Pinout
Does anybody have a pin-out of the body control module? I'm having electrical problems. it seems if I wiggle the connectors on there my car behaves differently. Afraid I might have a loose connection in a couple of them.
thanks.
Old Nov 6, 2007 | 03:18 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There are 3
Connector Part Information
12110244
24 Way F Micro-Pack 100 Series (PNK)
Pin
Wire Color
Circuit No.
Function
A1-A2
Not Used
A4
WHT/BLK
1073
Ignition Key Resistor Feed
A4
ORN
1640
Fuse Output - Type III Fuse
A5
Not Used
A6
BLK
999
ALC HDLP Relay Control
A7
YEL/BLK
1138
Ambient Light Sensor Input
A8
Not Used
A9
BLK/WHT
851
Ground - Clean
A10
LT GRN/BLK
1137
Ambient Light Sensor Ground
A11
Not Used
A12
DK BLU
1393
Interior Lamp Relay Output - Coil
B1
Not Used
B2
PPL/WHT
1074
Ignition Key Resistor Return
B3
GRY
1901
Rear Fog Lamp Relay Control (Export)
B4
DK GRN/WHT
1317
Fog Lamp Relay Output - Coil
B5
Not Used
B6
LT GRN
1037
Serial Data Signal - Class B - 10400 BAUD - Diagnostic To Body Module
B7-B8
Not Used
B9
LT BLU
1344
Trunk Release Relay Output - Coil
B10
BLK
28
Horn Relay Output - Coil
B11
Not Used
B12
GRY
2169
TONN REL Relay Control (Convertable)
12110245
32 Way F Micro-Pack 100 Series (PNK)
Pin
Wire Color
Circuit No.
Function
C1
DK BLU
38
Back Up Lamp Relay Feed - Coil
C2
GRY/BLK
745
Door Ajar Switch Signal - LT FRT
C3
WHT
193
RR Defogger Relay Output - Coil
C4
ORN
640
Fuse Output - BATT - Type III Fuse
C5
Not Used
C6
TAN
159
Key Reminder Switch Output
C7
Not Used
C8
Not Used
C9
PNK/BLK
109
Hood Ajar Switch Signal
C9
DK BLU
2167
Folding Top Lid Latch Signal (Convertable)
C10
PPL
681
Rear Defogger Switch Signal - Secondary
C11
LT GRN
2166
Folding Top Release Input (Convertable)
C12
RED/BLK
744
Trunk Ajar Switch Signal
C13
DK BLU
2167
C14
LT GRN/BLK
80
Key Reminder Switch Signal
C15
LT GRN
1601
Steering Column Lock Signal
C16
Not Used
D1
BLK/WHT
746
Door Ajar Switch Signal - Right FRT
D2
Not Used
D3
Not Used
D4
ORN/BLK
192
Fog Lamp Switch Output - FRT
D5
LT BLU
187
Fog Lamp Switch Output - RR
D6
Not Used
D7
DK BLU
15
Turn Signal Lamp Feed - RT FRT
D8
LT BLU
14
Turn Signal Lamp Feed - LT FRT
D9
BLK
1576
Trunk Release Switch Output
D10
Not Used
D11
DK GRN
306
Headlamp OFF Input
D12
YEL
243
Fuse Output - Accessory - Type III Fuse
D13
PNK
1039
Fuse Output - Ignition 1 - Type III Fuse
D14
DK GRN
911
Sterring Column Lock Relay Control
D15
BRN/WHT
1571
Traction Control System Switch Signal
D16
LT GRN
1966
DRL RH Relay Control
12110259
16 Way F Micro-Pack 100 Series (GRN)
Pin
Wire Color
Circuit No.
Function
A1
Not Used
A2
BLK
150
Ground
A3
GRY/BLK
690
Courtesy Lamp Relay Output - Coil
A4
ORN
2540
Not Used
A5
YEL/BLK
1784
Park Lamp Relay Control
A6
PPL
1604
Steering Column Unlock Feed
A7
ORN/BLK
1976
DRL LH Relay Control
A8
ORN
1603
Steering Column Lock Feed
B1
BRN/WHT
1244
I/P Lamp Feed #2
B2
YEL
390
I/P Panel Lamp Feed - Tertiary
B3
Not Used
B4
YEL
183
Fog Lamp Indicator - FRT
B5
Not Used
B6
GRY
8
Instrument Panel Lamp Feed
B7
YEL/BLK
625
Vehicle Anti - Theft System Starter Enable Relay Output Coil
B8
TAN
159
Old Mar 31, 2023 | 10:14 PM
weinerschizel
Thanks! Oddly enough, I'm just getting to this. I've isolated my issue but need to tap onto the speedometer signal, somewhere the line is broken.
To BCM Pinout
