Roadwalk!
Old Nov 19, 2001 | 07:25 AM
tds69tx's Avatar
tds69tx
Default Roadwalking Frontend!
I recently purchased a 97 C5 with 19k miles on it. It now has 21k. My question.....the car roadwalks on uneven pavement. It has the original Goodyears (yuk) on it with only about 35% of the tread life remaining on the front. Is this problem related to the worn out tires and/or the front end aligment?? I did take a ride in another C5 with the new Firehawks and couldn't believe the difference.
Thanks---TD :confused:
[Modified by tds69tx, 2:56 PM 11/19/2001]
[Modified by tds69tx, 4:53 PM 11/19/2001]
Old Nov 19, 2001 | 06:51 PM
tds69tx's Avatar
tds69tx
Default Re: Roadwalking Frontend! (tds69tx)
So am I to understand I am the only guy that has had this problem---thats kinda scarey
Old Nov 19, 2001 | 06:59 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
NO....you aren't the only one. Mine would almost change lanes on badly rutted roads. :eek: Since I went with the Michelin Pilot Sports, no problems :D
Old Nov 19, 2001 | 07:29 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I got another 30K to go, my tires look almost new at 10K.
Old Nov 19, 2001 | 07:56 PM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Re: Roadwalking Frontend! (wallstAL)
the shoulder on the Goodyear tires are very square... the Firehawks have a rounded shoulder... I dumped my EMT's for the Firestones a month ago... I had probably 50% tread remaining on the Goodyears... wasn't a hard decision to make... the difference in ride and handling ws worth it.
Old Nov 19, 2001 | 09:29 PM
TurboTnZ06's Avatar
TurboTnZ06
Default Re: Roadwalking Frontend! (XmentalPilot)
On a bad road, my supercars on the Z06 take the front end all over the place...In the rain, now that can be testing. I had to let the car change lanes once because it wanted to on a bad stretch of highway in the wet stuff. At least I know active handling works when it hydroplanes those 295's out back...
To Roadwalk!
