so where are the grounds?
Old Nov 9, 2007 | 12:33 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default so where are the grounds?
The only tow I can find using the diagram provided in the service manual are the two by the front wheel wells... I cannot find any of the others.
trying to correct the "service abs, service traction" issue
pics would be helpful or, failing that, a description of where each can be located. For instance, I the picture says there are two grounds located by the hinges to the doors... but I cannot find them, are they in the door? behind the dash?
Old Nov 9, 2007 | 01:09 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
try the search feature "service abs"
Old Nov 9, 2007 | 01:13 AM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
Check the Stickies in this section, huge post on electrical issues. There's a diagram of the ground locations.
Old Nov 9, 2007 | 03:54 AM
lucky131969's Avatar
lucky131969
Before you go on a wild goose chase, what codes are you getting?
Old Nov 9, 2007 | 08:35 AM
rws.1's Avatar
rws.1
there are two on the block... one directly above the starter the other in a simlilar spot on the driver side.
Old Nov 9, 2007 | 08:38 AM
rws.1's Avatar
rws.1
here's a link to Bill Curlees post on electrical issues in the stickies...
scroll down a bit and you will see that he has identified the ground locations
http://forums.corvetteforum.com/showthread.php?t=896875
Old Nov 9, 2007 | 11:39 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I know... that's the diagram I am talking about... it's wrong.
Old Nov 9, 2007 | 01:06 PM
rws.1's Avatar
rws.1
PM Bill Curlee... and talk to him....
Old Nov 9, 2007 | 01:18 PM
cam99's Avatar
cam99
What do you mean its wrong?
Old Nov 9, 2007 | 03:49 PM
Bill Dearborn's Avatar
Bill Dearborn
Since you have a 2000 here is the info you need. Your EBCM is grounded at two points. G108 and G101. 2001 and newer cars EBCMs are grounded at G108 and G103. G101/103 are the grounds for the pump motor circuit which involves the internal relay in the EBCM. G108 is the ground for the EBCM electronics.
Substitute G101 where you see G103 in the pictures.
Bill
Old Nov 9, 2007 | 03:54 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
why thank you... that is most helpful!
Old Nov 10, 2007 | 10:05 AM
lucky131969
Did you check the DIC for codes?
Old Nov 11, 2007 | 03:15 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
Here is what I got.
Keep in mind, I just switched the battery out.
They are all history codes, because it wasn't giving me any errors when I ran them.
I cleaned the three under hood grounds as well, but it keeps coming back intermittently however.
That said, here is what I have:
TCS: C1243
LDCM: B2283, B2284, U1064
RDCM: B2283, B2285, U1064
SCM: B0851, B2605
RFA: U1096, U1064, U1016.
again, they are all history codes.
it looks like the only one that is relevant is the TCS C1243: BPMV Pump Motor Stall.
To so where are the grounds?
